TPS problem.
Old Jun 28, 2004 | 05:24 PM
hondacivic4g's Avatar
Default TPS problem.
Ok my car hesitates for a second when I stomp the pedal and my Air Fuel meter goes from Rich to deep into lean. So today I started checking things under the hood. Well I took the plug off the TPS for about 10 seconds and the idle changes.Then I plug it back in and the hesitation isn't there and the car feels alot stronger. But if i shut the car off and start it again, the hesitation comes back, but i can do the same process and get rid of it.
So does anyone know what's up w/ my TPS?
Is it just going bad and needs replaced?
Old Jun 28, 2004 | 07:22 PM
Default Re: TPS problem. (hondacivic4g)
TTT
Old Jun 28, 2004 | 07:32 PM
dunkd's Avatar
check it with a voltmeter... TPS should read .45 at idle and then .50 at WOT..
Old Jun 29, 2004 | 12:43 AM
honda_power69's Avatar
One other thing....unless you're running your air/fuel gauge to a wideband O2 sensor that you added to the exhaust yourself, it's not going to be acurate enough to trust 100% anyway. Its going to fluctuate...thats the nature of it.
Old Jun 29, 2004 | 02:03 AM
Xsi's Avatar
Xsi
Are you getting any error codes?
If your TPS has been altered try setting it, if it is still set from the factory don't touch it.
http://www.integra.orcon.net.nz/tps
Old Jun 29, 2004 | 05:25 AM
Mike@CCT's Avatar
Formerly Mike@TSR
Default Re: (feri0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by feri0 &raquo;</TD></TR><TR><TD CLASS="quote">check it with a voltmeter... TPS should read .45 at idle and then .50 at WOT.. </TD></TR></TABLE>
Are you sure its not 0.5volts at closed throttle and 4.5volts at WOT?
Old Jun 29, 2004 | 05:51 AM
EE_Chris's Avatar
Default Re: (TSRperf)
You are correct TSRperf.
@ idle = .45v
@ WOT = 4.5v
pedrolucas
Sep 17, 2009 05:11 PM
jdm_eg
12
Nov 12, 2008 04:44 AM
LST2
Jan 20, 2008 06:37 AM
SuperRice
Jul 8, 2003 09:50 AM
