Car dies when i try to drive it!! help!
ok well i have 94 del sol. i just swapped in a d16z6 bc my b16 blew. the car starts right up and idles fine, but as soon as i try to give it any kinda load the car starts to die n bog n doesnt wanna move anywhere. I have already searched n tried almost everything. there is fuel spark for sure. and everything is plugged in right. n how do i check to see if tps is bad could that cause the car not go as soon as i try to engage the clutch n give it alil throttle.
Re: (jdm_eg)
The signal from the O2 sensor is required for the ECU to determine the optimal air/fuel ratio to burn in the cylinders. Fix the O2 sensor problem first and then go from there.
Re: (civ4life)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civ4life »</TD></TR><TR><TD CLASS="quote">it would be either that your tps is bad or idle air is bad... it could just be where ur plugs r backward on ur tps and idle air... to check ur tps u need a dvom</TD></TR></TABLE>
did it on my hatch and it wouldnt rev past like 3k...could prolly be it. it would idle fine but once you revved it, it would fall on its face.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_eg »</TD></TR><TR><TD CLASS="quote">only Cel is o2 could that do it?</TD></TR></TABLE>
nah...it shouldnt affect it. you could drive your car without an o2 but you would be running rich as hell. so im doubtful thats your problem.
Re: Car dies when i try to drive it!! help! (5hiftdhatch)
I pmed ya or give me a call 7177993233<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5hiftdhatch »</TD></TR><TR><TD CLASS="quote">You still have the car forsale let me know </TD></TR></TABLE>
ok well i checked almost everything n im stumped here. i found out that my bottom coolant hose is complete cold but everything else is hot. the temp is about half way n the bottom hose is still cold. could a thermostat problem cause this????
awdriscol4
04-26-2005 02:45 PM
SuperRice
07-08-2003 09:50 AM
