Question about Master Cylinder swap
Old Jun 28, 2004 | 05:13 PM
MLogan's Avatar
Default Question about Master Cylinder swap
I have noticed the that brake pedal in my CRX Si has been slowly falling to the floor if I put much pressure on it. I especially notice this at autox's. I bled the brakes, but this did little to improve the problem.
My question is, after 170k miles, is the MC shot? Should I get the 15/16th MC mentioned in this post https://honda-tech.com/zerothread?id=364783 or should I go for the CRX MC? What size is the CRX MC?
TIA
Old Jun 28, 2004 | 05:16 PM
mr. carpenter's Avatar
Default Re: Question about Master Cylinder swap (MLogan)
i would just get the stock mc unless you plan on or have already done a brake upgrde.
Old Jun 28, 2004 | 05:29 PM
MLogan's Avatar
Default Re: Question about Master Cylinder swap (mr. carpenter)
I am already using Super Blue fluid and plan on getting Axxis pads. This isn't really upgrading the brakes, but I felt the firmer pressure would be useful in autox, which is why I got the CRX.
Old Jun 28, 2004 | 05:35 PM
i stayed with the stock mc and have not had trouble with the autox or hpde's. those pads are going to make a noticable difference. make sure you bed them in properly. i just read a large article in sportscar magazine talking about how braking systems are designed with the proportioning valves specific for that brake setup. so increasing the mc ratio might cause easier lockup and premature pad and rotor wear. this was just an article mind you so you might want to im the guys that have done it and see what they think.
Old Jun 28, 2004 | 05:48 PM
MLogan's Avatar
Ok, thanks for the advice. The only other consideration is the 1991 civic ex (15/16th) MC is a few bucks cheaper than the crx.
Does anyone know the size of the MC in the 1991 crx si? I really need to get a helms for this car next.
Old Jun 29, 2004 | 04:18 PM
MLogan's Avatar
Anyone?
Old Jun 29, 2004 | 04:29 PM
FourthGenHatch's Avatar
90-93 Integra MC and booster, big improvement in pedal feel.
Old Jun 29, 2004 | 04:56 PM
4drEF's Avatar
Keyboard Humorist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MLogan &raquo;</TD></TR><TR><TD CLASS="quote">Ok, thanks for the advice. The only other consideration is the 1991 civic ex (15/16th) MC is a few bucks cheaper than the crx.
Does anyone know the size of the MC in the 1991 crx si? I really need to get a helms for this car next.</TD></TR></TABLE>
It's either 7/8 or 13/16. You can see for yourself what it is by looking around on the master cylinder for the exact size numbers casted into it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FourthGenHatch &raquo;</TD></TR><TR><TD CLASS="quote">90-93 Integra MC and booster, big improvement in pedal feel.</TD></TR></TABLE>
Why bother with the trouble of replacing the booster when all you have to do is trade out the MC with the sedan EX MC???? They are the exact same size MC's.... different bolt pattern, but still - the SAME size
Old Jun 29, 2004 | 05:30 PM
Default Re: Question about Master Cylinder swap (4drEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF &raquo;</TD></TR><TR><TD CLASS="quote">
Why bother with the trouble of replacing the booster when all you have to do is trade out the MC with the sedan EX MC???? They are the exact same size MC's.... different bolt pattern, but still - the SAME size</TD></TR></TABLE>
Because the Integra has a bigger booster than the EX does.
Bigger MC = less travel pushes more fluid.
Bigger booster = less pedal effort to accquire more force.
Old Jun 29, 2004 | 05:34 PM
4drEF's Avatar
Keyboard Humorist
Default Re: Question about Master Cylinder swap (FourthGenHatch)
I don't think you'll notice the diffence between the 2 boosters. It's pretty easy to press down the stock pedal. Adding a bigger MC isn't going to make it any harder to push. However, adding a larger booster can (and has in peoples cars) mess with your idle because you loose vacuum to the booster when you press the pedal down.
Old Jun 29, 2004 | 05:55 PM
Bgladfelter's Avatar
Also, you can use the old Prelude, 2.0 Si's MC. It bolts right up to our Booster, the 90-93 teg doesn't.
ludesrv
Oct 28, 2012 03:53 PM
melaccord98
Jul 7, 2010 05:51 AM
hatchbkdrvr
Oct 22, 2006 09:14 AM
luciffer
Aug 25, 2005 01:15 PM
Rob.
Jun 28, 2005 05:08 AM
