BRAKE UPGRADE
Old Jun 28, 2004 | 04:23 PM
ILCD5's Avatar
Default BRAKE UPGRADE
I HAVE A 97 ACCORD SE. I WAS WONDERING IF ANYONE HAD ANY FRONT BRAKE UPGRADES-(BIGGER ROTOR AND CALIPER) I KNOW THAT THE ACCORD WAGON HAS A BIGGER BRAKE SET-UP BUT DON'T KNOW IF IT WILL WORK ON MY CAR.
Old Jun 28, 2004 | 04:31 PM
madd's Avatar
Default Re: BRAKE UPGRADE (ILCD5)
try this
http://www.accordinglydone.com...n=5th
and lay off the caps
Old Jun 30, 2004 | 07:46 AM
ILCD5's Avatar
Default Re: BRAKE UPGRADE (madd)
Thanks for the info.............look no caps
Old Jul 3, 2004 | 03:10 PM
RABBIT9's Avatar
I'm using the 11" rotors from the wagon and I'm very happy with the results. If you do this, you're going to have to use the wagon caliper brackets also.
I just bought the kit from the Accord Store that came with drilled 11" rotors, caliper brackets, and carbomet brake pads. You can probably do it a little cheaper if you piece it together.
Old Jul 3, 2004 | 05:49 PM
f22b-dohc's Avatar
wagon calipers---doing this very soon.. i just need pads and actual rotors...
4th gen wagon calipers and itr's are the same....
farewell to my 14inch donuts
Old Jul 3, 2004 | 07:16 PM
fw190bvi's Avatar
Default Re: (f22b-dohc)
do the wagon wheels require 16"+ wheels to clear caliper??.....
what are the spec on wagon calipers??
Old Jul 3, 2004 | 08:08 PM
Nick H's Avatar
New User
Default Re: (fw190bvi)
why would you upgrade to the wagon callipers when the legend 2 piston callipers are probably cheaper (or similar priced) and come with larger pistons than the nsx callipers...just my .02...i'm using this setup and it stops pretty quick...
Old Jul 3, 2004 | 08:19 PM
fw190bvi's Avatar
Default Re: (Nick H)
so wagon fronts are 1 piston as well????......
OT: ive recently fallen in <FONT COLOR="red">love</FONT> with old legends........
Old Jul 3, 2004 | 09:37 PM
Conechaser's Avatar
All Honda/Acura calipers are 1 piston except for NSX and certain Legend calipers.
You can run legend/cl 3.0/prelude vtec brakes w/ 15" wheels.
My setup is
Accord Wheel Bearings
CL 2.3 Hubs
CL 3.0 Rotors
Prelude VTEC Calipers/Brackets
This setup fits under my stock 7spoke rims and my 15" Kosie Rims.
This converts your brakes to rotor over hub, instead of hub over rotor.
Oh, I have Accord SS lines, but they don't fit right w/ Prelude brakes, the brakes pulls the line to short, so you can't bolt the line down to the knuckle, nothing a ziptie or 2 can't take care of though.
Old Jul 3, 2004 | 09:46 PM
The_Todd's Avatar
Farts in the shower
Default Re: (Conechaser)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Conechaser &raquo;</TD></TR><TR><TD CLASS="quote">You can run legend/cl 3.0/prelude vtec brakes w/ 15" wheels.
NTM its cheaper/lasts longer and will be a very nice upgrade comparible if not better than a typical 'brembo' aftermarket kit.
bhaskarcs
Dec 16, 2017 08:27 AM
theLemur
Nov 17, 2011 06:33 PM
skweaky
Mar 7, 2006 08:39 AM
blueturboteg
Dec 3, 2003 03:27 PM
InfamousRS
Feb 11, 2002 05:23 PM
