would a bad cylinder position sensor cause the car not to start?
Old Jun 28, 2004 | 01:57 PM
dub204's Avatar
Default would a bad cylinder position sensor cause the car not to start?
i've had a no starting problem for 3 weeks now, there is spark, fuel, and the timing is right, the last time i tried to start it it threw a code 9, which is the cylinder position sensor.
BTW its a crx w/ b20
Old Jun 28, 2004 | 01:58 PM
Dyn0speed's Avatar
Default Re: would a bad cylinder position sensor cause the car not to start? (dub204)
sure! must be ur propz and tats spark
Old Jun 28, 2004 | 02:02 PM
paybac4223's Avatar
Default Re: would a bad cylinder position sensor cause the car not to start? (Dyn0speed)
are you sure that your timing is lined up correctly?
Old Jun 28, 2004 | 02:21 PM
dub204's Avatar
Default Re: would a bad cylinder position sensor cause the car not to start? (paybac4223)
ya timing is perfect. it was running fine, then the next morning i went out to start it and it wouldnt go.
Old Jun 28, 2004 | 02:30 PM
paybac4223's Avatar
well i have had a code 9 on a few diffrent occasions and it never caused my car not to start.... did you do anything else to the car???
Old Jun 28, 2004 | 03:08 PM
dub204's Avatar
nope, just stock b20, with aem fuel pressure regulator. it ran really strong, for one day, then didnt go again. i changed the distributor out of a known running car. i'm completely out of ideas, i'm going out tonight to check resistances.
Old Jun 28, 2004 | 04:21 PM
paybac4223's Avatar
maybe you blew a fuse..... does your check engine light come on for a few seconds when cranking???? check fueses under hood and dash carefully...also check ecu to see if the light blinks....
julianbc2
Jun 8, 2011 02:52 PM
jdmallmotorhatch
Aug 15, 2008 11:03 PM
jus2sho
Oct 18, 2006 03:44 PM
hmongboyLS
Jun 29, 2006 09:28 AM
The One Upper
10
Aug 7, 2005 07:11 PM
