need help mounting sir spoiler
im going to mount this on my Hf. the spoiler doesn't have LED. it has three screws one on each side and one in the middle, i know what to do with those
. but it also has two plastic things, one on each side right beside the screw. they stick out of the wing about an inch and are just a little wider than the screw. what are these used for? i need to know if i need to drill 3 holes or 5 holes.
you can take the plastic pieces of and just nut and bolt it.There is a stud under the plastic clip. The clips are used when installed from factory or dealer. It is not important to use them.
Toda Party
Jul 27, 2001 02:10 PM
