Code 22, VTEC pressure valve
Old Jun 28, 2004 | 12:39 PM
95exr's Avatar
Default Code 22, VTEC pressure valve
Swapping a H22 into my 95 accord.
My previous motor was VTEC so no extra wiring needed to be done. This is the only code we are having trouble with. We ran a check on it and the circuit is complete to the switch from the ECU, swapped in a new pressure switch and that never fixed it, doubled the ground and that never fixed it.
Any more suggestions of what we could try?
Old Jun 28, 2004 | 03:19 PM
Nick H's Avatar
New User
Default Re: Code 22, VTEC pressure valve (95exr)
vtec pressure switch is 21, vtec selenoid is 22 i believe...try swapping out the selenoid...
Old Jun 28, 2004 | 06:25 PM
4genaccordfreak's Avatar
Default Re: Code 22, VTEC pressure valve (Nick H)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nick H &raquo;</TD></TR><TR><TD CLASS="quote">vtec pressure switch is 21, vtec selenoid is 22 i believe...try swapping out the selenoid...</TD></TR></TABLE>
^^ yup.. just gunna say that... take off the whole solnoid assembly and make sure its not cloged.. clean everything out if nessesary.. and put it back on and try again.. might have to do that a couple times.. (DO NOT LOSE THE VTEC SOLENOID GASKET) if that doesnt work.. do what NICK H said.. and try finding another solenoid
ToeJam
Apr 3, 2008 06:01 PM
VTC_CiViC
Nov 17, 2004 09:05 PM
InfamousRS
May 21, 2002 04:09 PM
