Quick synchro question:
Old Jun 28, 2004 | 11:04 AM
Propulsion's Avatar
Default Quick synchro question:
At what part of the shift does the synchro do its job? Is it when you are moving the shifter into gear and before you let off the clutch?
Once the tranny is in gear, launching hard by reving it up and slipping the clutch will only wear the clutch and not the synchros right?
Old Jun 28, 2004 | 11:36 AM
rsbad454's Avatar
Default Re: Quick synchro question: (SilverCIVIC96)
they are for shifting.....key word synchronize.....when clutch is pressed, takes power away from tranny input shaft. Input shaft is now spinning a little slower. The synchros allow the shifter fork to move gear easier to its location.
Old Jun 28, 2004 | 12:16 PM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverCIVIC96 &raquo;</TD></TR><TR><TD CLASS="quote">At what part of the shift does the synchro do its job? Is it when you are moving the shifter into gear and before you let off the clutch?
Once the tranny is in gear, launching hard by reving it up and slipping the clutch will only wear the clutch and not the synchros right? </TD></TR></TABLE>That is correct. Specifically, after you've passed thru neutral, the synchro does its job as you're moving the lever into the new gear.
Old Jun 28, 2004 | 07:50 PM
Propulsion's Avatar
Default Re: Quick synchro question: (JimBlake)
got it, thanks guys.
ablack934doorcivic
Nov 1, 2005 02:02 PM
iixerOii
May 17, 2005 11:45 AM
dohcdelsol
Jan 7, 2005 10:11 PM
XES
Jul 18, 2003 09:22 AM
crxaddikt
16
Apr 4, 2002 05:25 AM
