Camber problems wearing my tires down
Old Jun 28, 2004 | 10:07 AM
93dx's Avatar
Default Camber problems wearing my tires down
I had my upper control arm replaced on my 93 accord. Since then my tire has wore on the inside. I had my tires rotated, and now the 'new' tire is worn on the inside too. What should I do?
I was told there are after market camber kits that may be able to fix the problem up to a few degrees. Any recomendations?
Old Jun 28, 2004 | 10:25 AM
Starrman85's Avatar
Default Re: Camber problems wearing my tires down (93dx)
get an alignment. if your not lowered any, then i dont know if a camber kit will fixt your problem, but you could always purchase one. but i would get an alignement if i were you.
Old Jun 28, 2004 | 10:29 AM
93dx's Avatar
No, I'm not lowered. And I have had an alignment and my tires balanced several times. But that hasn't helped.
Old Jun 28, 2004 | 11:16 AM
projekakkord's Avatar
What kind of control arm did you get? OEM or from somewhere else?
Old Jun 28, 2004 | 11:37 AM
93dx's Avatar
To be honest, I'm not sure. But I doubt it's OEM--unfortunately. Ohhh, all the things we should have done...
Old Jun 28, 2004 | 11:46 AM
.bagged's Avatar
Go get an alignment. you shouldnt need a camber kit for a stock car unless you have some unibody tweak problems
HondasGetDown
Apr 3, 2018 12:41 PM
eghatchfla
Jan 5, 2010 04:05 PM
Don JD
10
Sep 23, 2009 08:04 AM
EF_9
Apr 9, 2008 02:45 AM
super jdm yo
Sep 7, 2006 08:41 PM
