Possible tranny/axle problem
Old Jun 28, 2004 | 09:34 AM
deSigi's Avatar
Default Possible tranny/axle problem
I just swapped a 98 GSR into my 96 Coupe. When I let go of the clutch, I feel a knocking sound and I can feel the car pull slightly. If I let out the clutch really slowly, it doesn't do it. If I let it out at a normal speed it knocks. It's not really loud, but it's enough to **** me off. It does it when I go into reverse as well. When I'm rolling, if my timing isn't perfect when switching from the clutch to the gas, I'll hear it a bit too (I can also feel it a bit, but not as much as when my car is still). It seems to do it with the lower gears than higher.
I don't get it, the axle are new (well technically they are newly rebuilt). Might it have to do with the axles. It gives me the impression that there migfht be some play in the axle, and the knocking happens when it grabs properly.
Any help or info would be appreciated. Oh BTW I searched, and I really didn't find any info. I found one post and I IM the guy who started the thread and didn't get a response.
Old Jun 28, 2004 | 09:43 AM
Sliced Beard's Avatar
Default Re: Possible tranny/axle problem (e-kay)
you could have a busted differential adn it is letting you know that some of the teeth are broken off
Old Jun 28, 2004 | 10:18 AM
deSigi's Avatar
Anyone else with info on this problem?
Old Jun 28, 2004 | 11:06 AM
deSigi's Avatar
I'm thiking I might have too much backlash in my differential.
pit.crew
Mar 16, 2012 10:35 AM
vtec25
Mar 7, 2010 07:55 PM
overtwo
Feb 21, 2008 10:05 AM
CRJenkins13
Aug 13, 2007 09:51 PM
greddy13
Jul 4, 2006 05:24 PM
