wiring help!
well i have a 90 hatch. my fan wont turn on unless i turn it on my self like with a switch or somethin. so i asked my friend where a power source was when i turn the key on.. he said the last thing i wanted to hear..."look in the fuse box" so i thought nothing bad could happen.. its only temporary...yeah, so i found a hot wire when the key was turned on in the fuse box under the hood which was the little clip with 3 wires next to the main 60A battery fuse. so my dumb *** spliced the fan power wire into the little clip, i think it was the black with yellow strip. so i drive down the road then my car shuts off but like every thing on like the dash lights and every thing was on, so i turned the key off, waited a second then turned the key on and i waited for the main relay/fule pump to kick on....it didnt! but the car did crank over just not start. so i tow the car back to the house(pissed off cause i hate hacking ****).i read and read for wiring diagrams for what the wires in the fuse box were for.. no luck. so i tried to run a little jumper wire for the battery to the little clip inside the fuse box and bling my car starts but only with that jumper wire? so my question is what did i fry or screw up? i looked through all the fuses and everythings good. HELP PLEASE!!!!
*edit* i forgot to mention that i did undo all the wiring i did to turn the fan on.
snowwhiterex
Jun 25, 2008 06:20 PM
