JDM Cluster/Stock cluster troubleshooting question....
Old Jun 28, 2004 | 06:59 AM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default JDM Cluster/Stock cluster troubleshooting question....
I have a friend who's having problems with his gauge cluster. He had a JDM ITR cluster and put the stock one back in. I swapped the faces between the clusters for him (not the motherboard, just the faces), but the gas gauge and temperature gauge don't work...speedometer & tach work fine.
Are you supposed to swap all the gauges or just the speedometer and tach and swap needles on the temp/gas gauge? What's the problem? What's hooked up wrong?
Old Jun 28, 2004 | 07:40 AM
Project X's Avatar
Default Re: JDM Cluster/Stock cluster troubleshooting question.... (RealTypeR)
I just swapped the green film at the back and everything works perfect.
Old Jun 28, 2004 | 08:59 AM
Dave-ROR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RealTypeR &raquo;</TD></TR><TR><TD CLASS="quote">I have a friend who's having problems with his gauge cluster. He had a JDM ITR cluster and put the stock one back in. I swapped the faces between the clusters for him (not the motherboard, just the faces), but the gas gauge and temperature gauge don't work...speedometer & tach work fine.
Are you supposed to swap all the gauges or just the speedometer and tach and swap needles on the temp/gas gauge? What's the problem? What's hooked up wrong?</TD></TR></TABLE>
oh wait, this wasn't on YOUR car that you called about? chit, what year car and what year cluster? some just swap in.
Old Jun 28, 2004 | 09:04 AM
Kendall's Avatar
Default Re: JDM Cluster/Stock cluster troubleshooting question.... (Project X)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Project X &raquo;</TD></TR><TR><TD CLASS="quote">I just swapped the green film at the back and everything works perfect.</TD></TR></TABLE>
This is what I've always done, and it's always worked for me. I do believe that the difference, as Dave implied, is the fact that the 94-97 clusters are slightly different from the 98-01 clusters.
Old Jun 28, 2004 | 09:30 AM
SMZ GSR's Avatar
Worked for me as well.
Old Jun 28, 2004 | 11:22 AM
Project X's Avatar
Default Re: JDM Cluster/Stock cluster troubleshooting question.... (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote">
This is what I've always done, and it's always worked for me. I do believe that the difference, as Dave implied, is the fact that the 94-97 clusters are slightly different from the 98-01 clusters.</TD></TR></TABLE>
I do recalled when I swapped the '96 green film to the '98+ JDM is that few of the icons like the seatbelts, ABS, handbrake were in a different position. Just swap those ones from the '94-'97 and that's it.
Old Jun 28, 2004 | 02:52 PM
BERT-O's Avatar
lube it with some 151. after that take a shot and see what happnes,lol
it sounds like it just fail on you or a bad lead somewhere
Old Jun 29, 2004 | 12:21 AM
vecspeed12's Avatar
Default Re: JDM Cluster/Stock cluster troubleshooting question.... (BERT-O)
i didnt go the route of doing the green film. i took out the gauges itself from the screws in the rear and swapped them into my original housing.
hope that helps.
gwegcivic
Feb 18, 2008 12:45 AM
tommy.
12
Aug 29, 2006 05:27 PM
huskmusk
Jun 5, 2005 06:58 PM
yellowctr97
Feb 23, 2005 11:09 AM
