Where to start???
Ok i'm an owner of a 97 itr motor, its in an eg but.... i'm looking to get some more power nothing outrageous its still gonna be daily driven and needs to be reliable. I wanna go N/A but don't know where to start.....i just need some advice as where's a good place to start remember its Daily Driven
P.S. just wanna see what u guyz think where's a good place to start an N/A-R build up?
The usual ... (if you know what N/A means then you should be able to figure out what I/H/E means).
Which I/H/E you chose depends on how much $$ you want to spend and how much more whp you'd like to add.
The more whp you'd like to add the more you'll need to think about rebuilding your 97 ITR motor with higher compression pistons, higher lift and longer duration cams and head work.
For further answers, see: https://honda-tech.com/zerothread?id=766629
- Avatar Guidelines
Common sense should rule however since some of you seem to lack it we have written the rules for everyone to see. You may use any avatar that does not fall under any of the following categories:
Sexually Explicit/Pornography (Clothed or not)
Nudity (regardless of whether private parts are shown or not)
Figures in a sexual or "prone" position (clothed or not)
Images that show private parts through clothing (eg: wet t-shirt pics)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed »</TD></TR><TR><TD CLASS="quote">The usual ... (if you know what N/A means then you should be able to figure out what I/H/E means).
For further answers, see: https://honda-tech.com/zerothread?id=766629</TD></TR></TABLE>
i'm aiming for anywhere around 200whp a little over would be fine with me
and i had planned on getting the jdm 4-1 header since i have a 97 itr mota
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opie »</TD></TR><TR><TD CLASS="quote">Hope you got that motor the right way. </TD></TR></TABLE>
Of course, police get mad when they pull me over and find out itz legit
and i had planned on getting the jdm 4-1 header since i have a 97 itr mota<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opie »</TD></TR><TR><TD CLASS="quote">Hope you got that motor the right way. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opie »</TD></TR><TR><TD CLASS="quote">Yeah, but she's hot Ed </TD></TR></TABLE>
haha
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso »</TD></TR><TR><TD CLASS="quote">Hot girls are availble on playboy.com this is Honda-tech.com where we find the *** of a ITR sexy </TD></TR></TABLE>
very well put changin avatar now
haha
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bonez21 »</TD></TR><TR><TD CLASS="quote">i'm aiming for anywhere around 200whp a little over would be fine with me ... </TD></TR></TABLE>
You're looking at a decent header, mid level cams (Toda B's or Skunk 2's), an intake, cat-back exhaust to make close to 200.
To go over you'll most likely need CTR (~12.3:1 pistons, a better header like SMSP or Toda) and headwork.
I forgot to add at least a VAFC/FPR or Hondata (for tuning A/F and timing control).
To go over you'll most likely need CTR (~12.3:1 pistons, a better header like SMSP or Toda) and headwork.</TD></TR></TABLE>
what would i look to spend on some Toda B's i'm not really a fan of the Skunk2's
but when u say CTR are you talking about the stock CTR pistons?
I used to have boost, so I don't know what cams are going for ...
Yes, the stock CTR pistons (stock bore or .25 mm over).
You could always find better/forged pistons but these seem to be the cheapest available while still giving a nicely higher compression ratio.
These are just the basics.
Just have fun for a while and then figure out how much you can afford to spend on the "improvements".
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bonez21 »</TD></TR><TR><TD CLASS="quote">THANX MAN seriously you've been a big help</TD></TR></TABLE>
No problem.
Rob ... GO TO BED!
No problem.
Rob ... GO TO BED!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso »</TD></TR><TR><TD CLASS="quote">So I guess I have to go now
Yeah, we've done enough damage for today!
</TD></TR></TABLE>Yeah, we've done enough damage for today!
whats this talk of a avatar...
also..
that you did
also..
that you did
