96 OBD II h23 to 92-95 OBD I jdm h22
Old Jun 27, 2004 | 10:07 PM
yeahdudebrown's Avatar
Default 96 OBD II h23 to 92-95 OBD I jdm h22
to anyone that has done a jdm h22 swap into a 96 or who knows how to do one i need help! i am buying a OBD I h22 long block from hmotors at the end of the summer and i hear u have to change some parts on ur jdm motor. I think you have to use OBD2 Distributor, Injectors, Throttle body, timing pulleys and engine harness. Someone also told me on OBD2 there are 2 sensors that read the 2 timing belt pulleys on the crank. the sensors have no place to bolt on to in the OBD1 h22's, so you have to change the oil pump. I want to be able to get all the parts i need and know what im doing before the swap instead of running into **** the whole swap. thanks (im leaving for Germany for 10 days on monday so just leave all the info yall can!)
Old Jul 10, 2004 | 11:16 AM
Default Re: 96 OBD II h23 to 92-95 OBD I jdm h22 (yeahdudebrown)
anyone?? please!
Goombajustin98
Jan 19, 2019 10:34 PM
medic4.life
Jun 22, 2007 03:09 PM
m00nr0ck Si
May 10, 2007 05:54 PM
yeahdudebrown
Apr 14, 2005 11:20 PM
