Changed my plugs, and i'm stumped...
Old Jun 27, 2004 | 08:58 PM
Armed Ferret's Avatar
Default Changed my plugs, and i'm stumped...
BONE STOCK 92 Integra
Symptoms that prompted me to check plugs:
huge power loss (like 40% or so)
500rpm idle (sometimes lower)
backfiring
pulled the plugs and cylinders 2 and 3 are big-time black, so i know i'm rich there (which would explain the backfiring). my question is, would running rich cause the power loss and low idle? all my vacuum lines are fine, so what could possibly be causing 2 cylinders to run way rich and the others to be fine?
funds are limited till thursday (it won't be heaps better then thanks to rent being due, but i'll have a couple hundred prolly more than i do now ), but i still have to drive the car between now and then.
any suggestions/thoughts are greatly appreciated.
And yes, I searched under "running rich" but nothing really helped with figuring out why only 2 of the cylinders would be as such.
Old Jun 27, 2004 | 09:10 PM
shocker's Avatar
Could possibly be an o2 sensor or you might have to replace your ignitor and rotor/cap.Try these things along with a compression test just to be sure and see what happens
Old Jun 27, 2004 | 09:14 PM
Default Re: (shocker)
1. Don't have a compression tester
2. Entire distributor is brand new from Acura about 3 months ago. Took ignitor out and tested, it's fine. Took coil out and tested, it's fine. Rotor and cap are both fine. All items mentioned are completely dry.
I'm gonna go to bed now. I've got a feeling the O2 sensor finally left a hot steaming pile on the living room floor.
just hope it makes it to base okay tomorrow.
Old Jun 28, 2004 | 03:01 AM
Default Re: (Armed Ferret)
bump for the morning crew.
i'll be at work till about 5 pm, so if you have any suggestions feel free to email mark.gardner@offutt.af.mil
Old Jun 28, 2004 | 10:00 AM
Sliced Beard's Avatar
it may be a longshot but check your injectors and your fuel filter, you will be amazed at what sorts of problems a clogged/bad fuel filter will create
GagnarTheUnruly
Engine Management and Tuning
Sep 23, 2017 07:09 AM
dbiker207
Mar 31, 2007 07:49 AM
bennyhonda7
Jun 21, 2005 12:49 PM
Joel_MN
Mar 30, 2004 05:07 PM
Nate B
Feb 10, 2003 08:26 PM
