Compression problem
Old Jun 27, 2004 | 07:55 PM
DOHC_EF's Avatar
Default Compression problem
I have the oppurtunity to get a DOHC ZC for very cheap but with cylinder #1 having a comprssion of 30. What could be the worst possible case.
Old Jun 27, 2004 | 09:51 PM
VTgringo's Avatar
Default Re: Compression problem (Caramel)
either new piston rings or the leak is in the valves (seals or bent valve.) It's not a big problem at all. both are fairly easy fixes if you're mechanically inclined at all.
Old Jun 28, 2004 | 06:01 AM
Curtis2kul's Avatar
Default Re: Compression problem (VTgringo)
that was exactly what my car was. 30 on one cylinder, so i took the head off and it was a chipped valve! the cylinder wasnt even firing! Most likly valves just do a leakdown test if ya know how
Old Jun 28, 2004 | 08:05 AM
Filthy Focker!'s Avatar
Default Re: Compression problem (Curtis2kul)
You really need to do a leakdown test. That will eliminate the piston ring possibility. To do this, squirt a tablespoon of oil in that cylinder and redo the test.
Now if you have access to pressurized air, you may want to shoot air in that cylinder and listen carefully where the air is leaking. Take your valve cover off for this if you wish
fs.
Old Jun 28, 2004 | 11:43 AM
DOHC_EF's Avatar
Default Re: Compression problem (filthy_shovel)
Thanx for the help, anyone else have any other input? And how much would it be to replace a bent valve like stated above.
Modified by Caramel at 9:21 PM 6/28/2004
Old Jun 29, 2004 | 03:31 AM
Caramel, don't waste your time trying to find the cost of replacing a bent valve. Test your problem first, then you will know what you are dealing with. It is not because someone had a problem that sounded like yours that it is what is happening to you... Do some tests first....
fs
nemesis25
Jan 12, 2015 04:17 PM
Team_Coast978
Engine Management and Tuning
Jun 10, 2013 10:58 AM
clean ass lude
Sep 13, 2009 07:30 AM
guedo148
Aug 14, 2008 05:12 PM
evotux
Nov 20, 2006 07:01 PM
