has any1 got their b16 register to a crx chassis?
i was just wondering if anyone has ever gotten their motor register at state referee yet, cuz i want to do it but dont know what are the requirement and the car is a 91 hf crx with b16a2 motor.... thanks..........
is the motor obd1? it need a us spec computer for that engine. I am in the process with my gsr engine. Ryan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dyn0speed »</TD></TR><TR><TD CLASS="quote">does my ecu have to be obd2 like the motor with the correct harnesses for the motor?</TD></TR></TABLE>
Yes, if you plan on wiring OBD-2 ECU and everything else has to match. Harness does not have to swapped completely unless you really want to go through the trouble but if not the stock harness has to be wired up to OBD-2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by APEX CRX »</TD></TR><TR><TD CLASS="quote">
Yes, if you plan on wiring OBD-2 ECU and everything else has to match. Harness does not have to swapped completely unless you really want to go through the trouble but if not the stock harness has to be wired up to OBD-2</TD></TR></TABLE>
He is right.
He is right.
mikej94civex
10
Feb 12, 2010 03:54 PM
Dyn0speed
Jun 29, 2004 10:41 AM
SPOONfdEK
May 27, 2003 06:32 PM
