interior swap question
this may be a noob question but if i dont ask ill never find out...
i wan tto swap black interior into my eg. everything im ok with but the dash im afraid to do it cause everyone says that once you take off your dash it never goes back on right and rattles... do you guys have the same problem or no?
thanks
-kyle
thanks
-kyle
there is a bolt on the right side of the glove box top bolt and one on each side of the dash ( you have to pop off the covers and there is one dead center under your console at the floor, and also the top center vent has to come out because there is one behind there as well, make sure you disconnect the heater control cable and the ground (both on the passanger side behind the dash, and make sure when you put it ack in you reconnect those, if you forget the ground nuthin on your dash will work, so if that happens you will know why
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
I have removed my dash a few times as well, never had any rattling problems, I guess it is just making sure you put it all back together right and tight. Have fun, you will have to take out both airbags and the steering wheel.
O3DigitalBath
11
Dec 24, 2004 02:02 PM
Stryker908
13
Jan 5, 2003 07:42 PM
