96 ex power windows?
Old Jun 27, 2004 | 12:27 PM
dohc boy 96's Avatar
B A N N E D
Default 96 ex power windows?
all of a sudden my drivers side window does not go up or down but the pass side works perfectly from the drivers side switch. i checked the fuses and they aren't blown. what should i do? i wanna hit you guys up first before i take my car to honda and get charged a grip. help me out guys!
Old Jun 27, 2004 | 08:53 PM
B A N N E D
Default Re: 96 ex power windows? (sohc boy 96)
TTT has this happen to anyone?
Old Jun 27, 2004 | 09:00 PM
rex03's Avatar
the motor might be shot.....
Old Jun 27, 2004 | 09:06 PM
skip.two's Avatar
take of your door panel. maybe a wire is loose.
Old Jun 27, 2004 | 11:51 PM
B A N N E D
Default Re: 96 ex power windows? (jL iLLuZiOnz 9)
motor is working fine for the passenger window... just the drivers side doesnt go up or down. i did take the door panel off and everything looks in tact. its wierd cause the window goes does randomly... like lets say i first start my car up... then immediately put the window down... and it goes down... then after like 2 minutes its stuck. im all wtf?
Old Jun 28, 2004 | 03:38 AM
civicjester's Avatar
I have a 97 coupe, the tracks are not steel they are aluminum so they bend very easily, what you have to do is take off the door panel and make sure that the window is still on the track there are two 10mm bolts that hold the track in place. you just losen those two bolts and re-situate the window into the track hold them in the spot you want and tighten them down, careful cause if you crank on the bolts you will strip out the holes, so just tighten them down good not great, this will happen to you again its common on civics, i have had it happen at least 10 times, i have the repair time down to 5 mins ive done it so much
Old Jun 28, 2004 | 04:15 AM
Kista20's Avatar
it def. sounds like your motor. Mine had gotten off track in the winter which sucked big time. When I got off work I pulled it into the bay and took off the panel and found that it had come off the front track so I had to remove a bolt thats at the lower part of the door where it allowed me to swing the track back and forth so I got it around the edge of the glass and held it as tight as I could and tightened the bolt back up. Window has worked perfect ever since. Now all I have to do is figure out why the passenger window goes up/down slow in the winter time.
Old Jun 28, 2004 | 07:10 AM
Boosted96EK's Avatar
Check your grounds and all the fuses... there are fuses for each door...
inaety
Jun 7, 2010 11:53 PM
smooz EK
11
Dec 5, 2006 12:08 PM
Grimm
13
Jan 6, 2005 12:16 PM
CRXstress
Aug 1, 2004 01:59 PM
icefirezero
Jun 13, 2004 04:03 AM
