cannot pull code from ECM
Old Jun 27, 2004 | 10:56 AM
daniel_jian's Avatar
Default cannot pull code from ECM
Dear All,
I am quite new to this community, and I do not know where to post. So, pardon me if I post this at the wrong place.
I need a suggestion on the following:
My car's check engine light is on all the time. I went to Honda Dealer to check my Honda Accord 1995 EX. This is the report I got: "Cannot pull code, not getting a signal from the ECM." Anybody know what may cause this problem? Using an online guide, I tried to pull the code myself by jumping the connector under the glove box, but the check engine light did not flash the code as I expected.
Any help will be appreciated. Thank you!
Old Jun 27, 2004 | 11:07 AM
Joseph Davis's Avatar
Default Re: cannot pull code from ECM (daniel_jian)
It's referred to as CEL 0, meaning the ECU will not offer a code. Either some wiring is proper fucked so that the ECU doesn't know wtf is going on, or else the ECU is proper fucked and needs replaced.
LoGaN-VanG
Honda Civic (2001 - 2005)
Jul 1, 2009 08:18 PM
speedracer33
Jun 15, 2005 08:29 PM
HATCHFIEN
Nov 1, 2004 10:00 PM
DOHCon15s
Sep 30, 2003 06:38 AM
uszcrx
Jul 27, 2003 02:37 PM
