Z6 main bearing replacement question
Old Jun 27, 2004 | 10:31 AM
no_one_'s Avatar
Default Z6 main bearing replacement question
I'm thinking of checking the bearing clearances on a '95 Z6. I was wondering if all the mains can be replaced by dropping the oil pan. The last one I saw looked like it would be very difficult to replace the upper end main bearing shells due to the oil pump and the flywheel.
I'm also wondering about main bearing wear. A buddy claims that the upper half of main bearings shouldn't get much wear as most of the loads are going to be directed downwards. He's recommending that I just ignore the upper main bearings and replace the lowers due to this.
If a main bearing was out of clearance, would I only hear it at idle, or would I notice it as the engine revved up? Kinda wondering what the H-T crowd thought of this. Thanks.
Old Jun 27, 2004 | 06:57 PM
no_one_'s Avatar
Default Re: Z6 main bearing replacement question (no_one_)
bump
Ulric Dulude
Engine Machining & Assembly
Mar 15, 2019 07:47 PM
pdiggitydogg
Dec 4, 2005 10:37 AM
auto moto
May 15, 2005 07:01 PM
turbociv
15
Mar 11, 2004 01:16 PM
ericlee303
Nov 17, 2003 08:54 AM
