Amp power and grounding with power distribution block
Old Jun 26, 2004 | 11:47 PM
Hoodwinked's Avatar
Default Amp power and grounding with power distribution block
Hey, quick question. I have two amps, one for my speakers, one for my sub. I am running a 4 awg power cable from my battery to a power distro block. From there, I have two 8 awg cables running out to the amps. My issue is with the grounding. Do I ground each amp with a 8 or 4 awg cable? How do I set up my grounding cables? Thanks!
Old Jun 27, 2004 | 05:32 AM
bassisliffe's Avatar
Default Re: Amp power and grounding with power distribution block (Hoodwinked)
you could do the same, run a 4awg from a good ground point and 8awg from the amps to a distro block that goes to the 4awg
Old Jun 27, 2004 | 07:15 AM
fcm's Avatar
fcm
Old Fart
Every connetion you make has resistance, so the less connetions the better.
Run your amp grounds to the same spot as close to amps as you can.
hope this helps. 94
Old Jun 27, 2004 | 12:49 PM
EnjoyTheRideDC2's Avatar
With a ground distribution block, Ground a string of 4GA wire (you choose your length and location) and stick the open end into the Ground Dist. Block. Then, spit 2 8GA strings out and to both of the amps.
94 IntegraLS
Audio / Security / Video
13
Dec 7, 2007 07:35 PM
djbrandonr
10
Jul 13, 2006 02:17 PM
honda95civic
15
Jul 25, 2004 09:06 AM
duttykruffy
Jul 7, 2004 02:32 PM
tinkerbell
Feb 18, 2004 07:06 PM
