what do you guys think about this setup.......
Very Emergency!!
b18c5: ctr pistons, spoon headgasket, skunk2 flat valves, springs, retainers, and the one thing i am unsure off, what cams do you guys think i should get for a mild street-track setup. hopping for two hundo at the wheels. thanks in advance for the help
i mite get flamed but loose the ctr pistons there tooo domyyy get some piston that dont have that big of a dome. running it with pump gas mite get a problem in hot nevada u have a bit comression with the gasket and the valves. plus the domy piston stuff this is wut i hear the amount of air fuel that actually gets into the motor will not be the same and ive also heard of the exhaust gases exiting the motor or something to do with the combustion i forget which but yea... but anyways if you still want to run that much compression get some jun3, skunk2 stage 2, not sure maybe rs machine cams.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoonDC2R »</TD></TR><TR><TD CLASS="quote">b18c5: ctr pistons, spoon headgasket, skunk2 flat valves, springs, retainers, and the one thing i am unsure off, what cams do you guys think i should get for a mild street-track setup. hopping for two hundo at the wheels. thanks in advance for the help
ctr pistons...negative, go with pr3's or p30's
oe headgasket, mess on spoon mess
go with ROCKET nae flat faced valves, nothing from skunk please
rlz or rocket springs and retainers are both very nice ( i use RLZ on my 230whp itr)
and cams...well, RLZ stage 2 cams are an excellent street cam...they can easily make over 200whp on b16's and more on 1.8L's
</TD></TR></TABLE>ctr pistons...negative, go with pr3's or p30's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2kgs-R »</TD></TR><TR><TD CLASS="quote">Can't he simply retard the timing if he had pinging problems because of running the ctr pistons? </TD></TR></TABLE>
thats *** backwards engineering. just run lower compression. theres no point in running high *** compression, than retarding timing...
Very Emergency!!
thanks for the help. i didn't really want to tear into the block, i just want a little more pep in its step. i had skunk2 stage ones and hated tem. i trade my friend the skunks for ctr cams. car runs way better and is faster. i was thinking a jun valve train.or toda. (if i can afford it.)
pootie.teng
17
Feb 20, 2007 08:06 AM
2.2motore
May 9, 2004 04:36 PM
JD_B18CDX
Dec 1, 2002 10:32 AM
