problems with cooling system on zc swap and no.1 cyl. position
Old Jun 26, 2004 | 09:37 PM
yllwmpfiDX's Avatar
Default problems with cooling system on zc swap and no.1 cyl. position
i just swapped a 90 zc into my 90 crx dx using a pr3 90 integra rs computer and i'm overheating even though my fan is kickin on i seem to be 180 degrees of on my crank pulley with the timing light my check engine light is flashing code 9 which is no.1 cylinder position sensor which is the crank angle sensor which i just rebuilt with japanese internals. if any of you have hade these problems or similar ones please help me i've invested way too much time, money and effort into my car to see it all go down like this. please help any and all comments will be greatly appreciated. thanks.
Old Jun 27, 2004 | 07:26 AM
4potnick's Avatar
Default Re: problems with cooling system on zc swap and no.1 cyl. position (yllwmpfiDX)
I have the same problems cyl position sensor. I have replaced everything in the ignition. with brand new parts. It's at the shop getting wires chased currently. good luck though
Old Jun 27, 2004 | 07:41 AM
MonoDestro's Avatar
All I can suggest is that I know the most common ECU's run with ZC's are the actual ZC ECU, PM7, or a PG7 from a '86-'89 Integra. I'm not sure if that would help the problem, but it is a suggestion. Don't worry, I'm sure someone will be able to help, and if not, check out http://www.thezcr.com. The site is dedicated to that engine.
Old Jun 27, 2004 | 07:46 AM
crxgator's Avatar
code 9 is your exhaust cam sensor that is next to your distributor...ts the little box you had to extend two blue wires too, first i would switch the blue wires, you might have them reversed...if that doesnt work get one from a 88-89 integra...
Old Jun 27, 2004 | 07:48 AM
crxgator's Avatar
Default Re: problems with cooling system on zc swap and no.1 cyl. position (4potnick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4potnick &raquo;</TD></TR><TR><TD CLASS="quote">I have the same problems cyl position sensor. I have replaced everything in the ignition. with brand new parts. It's at the shop getting wires chased currently. good luck though</TD></TR></TABLE>
wow its only two wires, and you probalby have em reversed and its not part of the distributor...
Old Jun 27, 2004 | 07:55 AM
4potnick's Avatar
Default Re: problems with cooling system on zc swap and no.1 cyl. position (crxgator)
Been there, tried that.
4potnick's Avatar
Been there, tried that. car ran fine for a while and then started having issues.
Old Jun 27, 2004 | 07:58 AM
crxgator's Avatar
so buy a used sensor off a teg...
the zc swap is so ******* easy with wiring, i dont see how you can **** it up...
Old Jun 27, 2004 | 08:33 AM
4potnick's Avatar
I am aware of how easy it is, about 6 wires. Sensor is brand new from acura. I bought the car as a shell so I don't know what is issues it already had. I love people who have no clue what the **** they are talking about. Car run great for a while. Hey crxgator, I guess the wires un-soldered themselves and then switched, re-soldered themselves and then even shrinkwrapped back together. stupid ****
Old Jun 27, 2004 | 10:08 AM
crxgator's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4potnick &raquo;</TD></TR><TR><TD CLASS="quote">I am aware of how easy it is, about 6 wires. Sensor is brand new from acura. I bought the car as a shell so I don't know what is issues it already had. I love people who have no clue what the **** they are talking about. Car run great for a while. Hey crxgator, I guess the wires un-soldered themselves and then switched, re-soldered themselves and then even shrinkwrapped back together. stupid **** </TD></TR></TABLE>
ok, then with all the money you spend on some guy to fix it, you can buy a brand new harness from honda and call it the day, and you wont have any wires that were fucked to begin with...not my fault you bought a car that was fucked from the begining, your the stupid **** that did that not me...
Old Jun 27, 2004 | 10:42 AM
yllwmpfiDX's Avatar
switched wires rebuilt sensor last night on the way to the sore for a pack of smokes the rev limit started hittin at like 3500 rpms now the bitch hardly wants to start.
EF'n
Feb 17, 2008 07:37 PM
89dohcEF
Mar 25, 2004 12:37 PM
Acid832
Aug 8, 2003 05:13 PM
WhatThaFrig
Apr 4, 2003 09:17 AM
