PR3's on ls rods??
anyone know if pr3's will fit on stock ls rods i kno jdm p30s do but i wanna make sure b4 i go buy pr3's cuz im havin a hard time finding p30's. also what will the cr be for pr3's in a b18a1
I'm not sure but you might have to get the pistons machined. The pin holes.
Check your Comp/Ratio here. http://www.c-speedracing.com/h...c.php
LS and B16a rods are the same width at the pin. no need to do any mods for the piston to be pressed onto the LS rod. same with Rod bearings for the LS and B16a....they are the same width in case you wanted to know
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DXDOHCVTEC »</TD></TR><TR><TD CLASS="quote">Don't you have to mill 1mm off the ls rods like an lsvtec setup?</TD></TR></TABLE>
No. That's only for PCT and P73 pistons (maybe P72's as well, I can't remember).
redrusch
Sep 16, 2007 10:54 PM
Acura_I-RS
Aug 3, 2005 07:27 PM
