d15 block, d16 head ... what parts?
Old Jun 26, 2004 | 06:37 PM
efracer's Avatar
Default d15 block, d16 head ... what parts?
car is '91 civic lx sedan ... stock d15 block ... put on was a '95 vx 1.6 head. does anyone know what timing belt i should be using? the one from the 1.5 is too big so i'm guessing get the one for the 1.6 vx head, is this right?
also the distributor doesn't line up .. surprise, surprise .. how do i enlarge the bolt hole? dremmel tool or is there another way?
if anyone can understand the nonsense i just typed and can offer help, i would be grateful.
Modified by efracer at 10:58 PM 6/26/2004
Old Jun 26, 2004 | 06:52 PM
dr_latino999's Avatar
Default Re: d15 block, d16 head ... what parts? (efracer)
Ok, let me clear some things up real quicky like...
Weren't the VX's 1.5 VTEC motors? And if so, you have a whole mess of worms to deal with. Also, are you trying to put in the stock DPFI distributor in there? You need to be using the distributor that came with that motor so you can run all 4 injectors but that would put you into OBD-2 land....so very late....I'll sleep on this and get back to you in the morning.
Old Jun 26, 2004 | 06:58 PM
efracer's Avatar
Default Re: d15 block, d16 head ... what parts? (dr_latino999)
the vx head may be a 1.5 .. i thought was a 1.6 but could be wrong. that shouldn't pose an issue though i wouldn't think.
the vx was a vtec but i'm not wiring up vtec, just running as a normal head.
yes, i am using the distributor off the '91 1.5 .... please tell me i can do this
oh, and if you can't tell .. i know **** about all this
Old Jun 26, 2004 | 07:22 PM
DieMaster's Avatar
Needs to be About 20% Cooler
my god it's about time i found someone that has the same car, year, modle, and body as me.
as for the dizzy, you could also try to make a bracket.
it's kinda obvius that you dont know and theres nothing wong with that
Old Jun 26, 2004 | 07:42 PM
1g Supremacy's Avatar
D15 block + D16 head = Hydra swap. There's a guy named Kirk over on RPR who's pulled it off..Took a D15A3 block and either a D16 or ZC head and put it all together in his 87 CRX. From what I've heard, it turned out quite well.
Old Jun 26, 2004 | 08:07 PM
splitime's Avatar
Default Re: (1g Supremacy)
Just use the VX timing belt. The VX is a d15z1.... 1.5L.
Old Jun 26, 2004 | 08:08 PM
GoGoGadgetVtec's Avatar
Default Re: (splitime)
do a search on "mini me"
Old Jun 26, 2004 | 08:28 PM
mr. carpenter's Avatar
Default Re: (GoGoGadgetVtec)
use the vx timing belt, correct. the dist. has to be modified and i've got a post on it that i'll find. the vtec is in the head but you can run without it. i don't know how well it runs but it will run. you just have to use your intake manifold and ecu. the vx head is basically the same as the d15b but with good ol' american emissions on it.
https://honda-tech.com/zerothread?id=687988
look at the pic in the thread. i also had to widen the hole on the top leg.
Old Jun 27, 2004 | 06:27 AM
efracer's Avatar
Default Re: (mr. carpenter)
cool .. so the distributor from the '91 d15 will work ... correct ? just want to make sure only issue will be getting it to stay in time by being creative.
also, the stock '91 d15 ecu will work ... correct?
Old Jun 27, 2004 | 07:30 PM
Default Re: (efracer)
read the post at the bottom of this thread. it explains how i did it.
https://honda-tech.com/zerothread?id=882370
i also was able to get my timing adjusted by using the dremel to grind notches in the legs that hinder movement. did that today and got timing set dead on.
Modified by mr. carpenter at 4:49 AM 6/28/2004
Old Jun 28, 2004 | 04:56 AM
efracer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr. carpenter &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by mr. carpenter at 4:49 AM 6/28/2004</TD></TR></TABLE>
hmm, good idea. i hope mine line up close enough.
gadawg31
Oct 31, 2012 07:17 AM
93formula
Mar 30, 2005 01:23 PM
Questy
Jun 16, 2003 08:20 AM
