2 easy questions
1. when people say "rods" what part of the engine is that? as in "crank, rods and pistons". is it the part that connects the pistions to the crank?
2. how does coolant cool the engine? where exactly is it pumped? do the fans do anything other than just blow air at the engine?
http://www.howstuffworks.com/
all of your how does this work needs. and the rods connect the piston head to the crank shaft.
coolent is pumped into the engine block which has small hole in it (when the head gasket blows u burn cooolent or oil) then the hot coolent goes in the raditor and cools off....it the same thiing ovre and over to cool the enginjne
all-mtr-teg
26
Jun 13, 2008 11:14 PM
Mike@CCT
28
Feb 28, 2005 10:09 PM
LudeyKrus
Jul 18, 2004 05:21 PM
