EF CRX motor swap help
Old Jun 26, 2004 | 05:57 PM
tcwcrxhf's Avatar
Default EF CRX motor swap help
Hey I was wondering if the 1.6 D16A6 is a direct bolt in to the HF CRX. I mean i know the motor mounts are the same. I just want to know if the wiring is plug and go or if i have to change any of it. This HF has a MPFI that came factory on the 1.5 D15B6.
Anyone have any advice?
Old Jun 26, 2004 | 09:43 PM
Steemo's Avatar
Default Re: EF CRX motor swap help (tcwcrxhf)
yeah and uhh use the search tool im sure theres tons of info on this.
Old Jun 26, 2004 | 09:44 PM
yllwmpfiDX's Avatar
yes the d16a6 is a direct bolt in into the hf engine bay all you have to do is take the engine harness off the hf motor and put it on the si engine i do advise doing this with both engines out of the car it is alot easier and faster. also use the si pm6 computer
Old Jun 27, 2004 | 08:01 AM
tcwcrxhf's Avatar
Default Re: EF CRX motor swap help (yllwmpfiDX)
arent the harnesses the same
Old Jun 27, 2004 | 04:42 PM
yllwmpfiDX's Avatar
no the harnesses aren't the same. yes, they are both multi-point motors but they wiring on an hf is ran form the opposite side of the car from an si and alot of the plugs are different. so you need the hf engine harness on the si motor. i had to do it when i had my old hf.
peiku
Feb 21, 2006 03:10 PM
Rocky's_CRX
32
Oct 16, 2005 05:04 PM
ITSTOCK
Nov 12, 2003 04:53 AM
paulzy
Jun 21, 2003 03:34 AM
91HATCH
23
Oct 15, 2002 05:03 PM
