will JE pistons work on stock gsr and or LS rods??
Old Jun 26, 2004 | 05:53 PM
mrbsponge's Avatar
Default will JE pistons work on stock gsr and or LS rods??
just wanted to knwo if JEs will fit on my stock honda rods, either LS or gsr?
thanks
Old Jun 26, 2004 | 06:46 PM
junkyard racer's Avatar
Default Re: will JE pistons work on stock gsr and or LS rods?? (mrbsponge)
yes but why would you do this?
get some rods to go with it. it will be worth it to save up the $400 they cost.
get vitara pistons.......
read the entire thread, and honda-tech's thread.
http://www.homemadeturbo.com/f...21002
Old Jun 26, 2004 | 07:06 PM
mrbsponge's Avatar
becaus ei have some ITR jdm & usdm but i spray alot and really dont know how long the would last so, i wanted to get something better than them
Old Jun 26, 2004 | 07:07 PM
mrbsponge's Avatar
i want 12.5:1 for higher comp, not low
AzG35's Avatar
Default Re: will JE pistons work on stock gsr and or LS rods?? (junkyard racer)
Yes, they do work on stock rods. I have them on my GSR rods with ARP rod bolts and its fine. But don't use the spiral locks, the pins must be pressed or heated onto the rods.
Old Jun 26, 2004 | 07:26 PM
mrbsponge's Avatar
what compression are you running, i want like 12.5. also can any normal machine shop press them in or do you recommend a certain type or place?
they are going in a gsr but i have an ls/vtec that i might want them in as well
Deco989
27
Jan 13, 2011 05:24 PM
delsol456
Mar 5, 2008 05:50 PM
the DA in HONDA
Feb 24, 2005 06:14 PM
LSTEG96
Oct 23, 2003 09:38 PM
Skippy
Oct 27, 2002 09:14 PM
