90 Civic A/C help needed
A/C is apparently a dealer-installed aftermarket unit, and the two relays are *not* the standard Honda relays. The ones in the car are 5-pin, with the top and center pins horizontal and the other three pins vertical. The dealer/auto parts store relays are 4-pin with a different pin configuration, so they won't plug in to the sockets.
Anyway, these look like standard 12V relays, but I've found two different replacements: one is a 70amp/800watt, and the other is a 30amp/350watt.
Any idea which one is correct for the A/C system? There is NO info on the existing relays. Any help appreciated! Thanks...
raja_wagon
Mar 28, 2018 08:30 AM
