Honda S2000 Honda S2000
Raising the redline
Old Jun 26, 2004 | 11:44 AM
Sideways's Avatar
Default Raising the redline
I recently bumped the redline (via the AEM EMS) to 9500 rpm. All I can say is unbelieveable. By lowering the V-tec engagement point 800 rpm and raising the redline 600 rpm it adds 1400 rpm to the power band. Adding 1400 rpm in the power band makes it feel like a racecar.
Anyone else bumped the redline on their S?
WARNING: Don't try this unless you have fortified your valve train.
Old Jun 26, 2004 | 02:21 PM
SimbaDogg's Avatar
Default Re: Raising the redline (Sideways)
Sideways, are you also on s2ki? also, what kind of valvetrain components did you use?
Old Jun 26, 2004 | 02:24 PM
Sideways's Avatar
Default Re: Raising the redline (SimbaDogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SimbaDogg &raquo;</TD></TR><TR><TD CLASS="quote">Sideways, are you also on s2ki? also, what kind of valvetrain components did you use?</TD></TR></TABLE>
Ti retainers, upgraded springs, lighter valves. Yes, I post on s2ki.
Old Jun 26, 2004 | 04:53 PM
SneezR's Avatar
video(s) would be great!
Old Jun 26, 2004 | 04:58 PM
Hypersonik's Avatar
That is on an 04 S right?
Old Jun 26, 2004 | 05:28 PM
evil vapor's Avatar
Default Re: Raising the redline (Hypersonik)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hypersonik &raquo;</TD></TR><TR><TD CLASS="quote">That is on an 04 S right?</TD></TR></TABLE>
no, it's on the 2.0L engine.
Becareful with raising the rev limit, while the head can support it, the high rev's eventually lead to bearing or rod failure. But I can say in you supercharged application, you'll see gains but there aren't any gains to be seen NA with raising the rev limit, only more wear and tear on the engine.
Old Jun 26, 2004 | 08:46 PM
Heath's Avatar
Default Re: Raising the redline (vapor)
Video would be awesome. I'd love to see and hear that.
Old Jun 29, 2004 | 09:01 PM
papa5murf's Avatar
sounds good, got any dyno numbers?
Old Jun 30, 2004 | 12:42 AM
evil vapor's Avatar
Default Re: Raising the redline (03s2kblue)
he's putting down 360whp on a dynapack, correct me if I'm wrong sideways.
Old Jun 30, 2004 | 09:07 AM
WRS2K's Avatar
If it ain't reliable for a long *** time, it's not worth the headache to most.
And I'm in with the most.
Old Jun 30, 2004 | 11:05 AM
Sideways's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vapor &raquo;</TD></TR><TR><TD CLASS="quote">he's putting down 360whp on a dynapack, correct me if I'm wrong sideways. </TD></TR></TABLE>
362.9 hp with 216 ft lbs torque.
you can see the dyno here: http://forums.s2ki.com/forums/...15021
I think it will be reliable for a long *** time. It sure is a kick to whoop a Z06 fair and square. At 2750 lbs, it's just under 7.6 lbs per horsepower now and with a little effort I could see 6.XX lbs per horsepower shortly.
Old Jun 30, 2004 | 09:53 PM
boostdd's Avatar
Becareful with raising the rev limit, while the head can support it, the high rev's eventually lead to bearing or rod failure. But I can say in you supercharged application, you'll see gains but there aren't any gains to be seen NA with raising the rev limit, only more wear and tear on the engine. </TD></TR></TABLE>
thanks for the info vapor, man u really know your chit.
Old Jun 30, 2004 | 10:24 PM
[S2X]'s Avatar
sideways,
i would like a ride in shot-gun to feel the power. raising the redline is pretty crazy and dropping the vtec point is like no waiting around.
so your vtec point is @5200 rpm??
what is the draw back when lowering the v-tec point?
Old Jun 30, 2004 | 10:28 PM
papa5murf's Avatar
nice numbers...
Old Jul 3, 2004 | 04:21 PM
Heath's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 03s2kblue &raquo;</TD></TR><TR><TD CLASS="quote">nice numbers... </TD></TR></TABLE>
I agree!
RacinMasonC
Nov 7, 2008 12:31 AM
accordf23
Aug 12, 2008 07:37 AM
accord03coupe
Honda S2000
17
Mar 27, 2007 03:28 PM
DB1_559
Oct 17, 2005 06:00 AM
itr1244
Oct 1, 2005 11:37 PM
