d15b swap, do you have to swap out any motormounts??
I was told I was going to have to swap the d15b drivers side motormount for the one from my cx,
is this true??
they look similar, hard to tell if they're the same or not,
but I just figured I'd ask here.
lmk
thanks.
is this true??
lmk
thanks.
i'm not sure but i don't think so, because if that was the case wouldn't yoou have to do the same thing to the d16z6? anyone?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VvPeachyvV »</TD></TR><TR><TD CLASS="quote">i'm not sure but i don't think so, because if that was the case wouldn't yoou have to do the same thing to the d16z6? anyone?</TD></TR></TABLE>
I would THINK they're all the same...
Actually I'm putting one into my '89 CRX right now and the motor mount is close but it definetely won't fit. You will need a motor mount, and maybe an ecu and harness. Also, if your just putting it into a stock CRX (DX model anyway) you're also gonna need the top end pipe for the exhaust because it is bigger on the VTEC manifold and will not fit your stock exhaust.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by usdmike »</TD></TR><TR><TD CLASS="quote">I helped put a jdm d15 into a cx two days ago. It fits fine with stock mounts
thanks!
and yeah i said cx not crx
</TD></TR></TABLE>thanks!
tei344
Sep 5, 2008 05:41 PM
blkhatch92
Nov 7, 2005 06:39 AM
Bodman
Aug 21, 2003 10:34 AM
