y5 mini me in EH
Old Jun 26, 2004 | 08:43 AM
egizzle8
Guest
Posts: n/a
Default y5 mini me in EH
I'm getting a y5 head really cheap to swap on my my y7 in EH. Would it run fine running off a P28? Wiring is no problem being my EH is a 92 and already wired for vtec. How much of a difference is there using just the head from a y8 to y5 performancewise besides the y5 with the roller rockers? The setup is just NA for now and maybe boosted in next couple months.
Old Jun 26, 2004 | 09:56 AM
egizzle8
Guest
Posts: n/a
Default Re: y5 mini me in EH (egizzle6)
yeah yeah I know it's a HX head but com'mon, the cold shoulder? It's just the tranny that makes the engine blow
Old Jun 26, 2004 | 03:44 PM
specv5150's Avatar
From what I have gathered......the HX has a different type of ECU. I forgot what someone called it (they may have called it run lean or some ****) I was going to run a P28 as well and get some form of engine management but I was told the car would run like crap. Plus you would have to set the VTEC crossover to 2K RPM. You can be a test dummy for us. I am really curious.
Old Jun 26, 2004 | 03:56 PM
egizzle8
Guest
Posts: n/a
Default Re: y5 mini me in EH (specv5150)
I don't see why it wouldn't run good on a p28 or anyother non vtec-e ecu? Its not like it's got a 2 or 3 stage vtec going on? Anyone got a suggestion to this matter?
Old Jun 26, 2004 | 04:04 PM
specv5150's Avatar
Do a search in this section for a turbo Y5 project. It was explained in there as to why it would run like crap. I basically asked the same questions.
Old Jun 26, 2004 | 04:06 PM
specv5150's Avatar
https://honda-tech.com/zerothread?id=753403
Here ya go...a little more info
NEVERMIND. I thought it was posted in there and I just read through and couldnt find anything but it is HERE. I know it. If you have the mini-me and a P28, just try it out and see what happens. I REALLY want to know...I want to switch to hondata or uberdata.
Old Jun 26, 2004 | 04:41 PM
HXvtec's Avatar
i think if u hook up a p28 to the y5 it would run like crap. reason being is that u will run on 8 valvle till about 5grand when regular vtec kicks in. id say get a p2n ecu. try asking spade about this. there was a topic about this before and the kid got flamed on.
Old Jun 26, 2004 | 04:49 PM
specv5150's Avatar
Default Re: y5 mini me in EH (HXvtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HXvtec &raquo;</TD></TR><TR><TD CLASS="quote">i think if u hook up a p28 to the y5 it would run like crap. reason being is that u will run on 8 valvle till about 5grand when regular vtec kicks in. id say get a p2n ecu. try asking spade about this. there was a topic about this before and the kid got flamed on.</TD></TR></TABLE>
What is P2N...OBD1 VX ecu?? Or is that the OBDII HX
Old Jun 26, 2004 | 04:52 PM
sohcvtec1995's Avatar
yea in imo i think this is not the best setup. just get a z6/y8 head and then run the pe8. since your car is obd1 that way you wont have to do anything extra other than the usual like vtec. Just make sure you do it properly.
HXvtec's Avatar
OBD II Hx<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by specv5150 &raquo;</TD></TR><TR><TD CLASS="quote">
What is P2N...OBD1 VX ecu?? Or is that the OBDII HX</TD></TR></TABLE>
Old Jun 26, 2004 | 04:54 PM
you could also run a p2p (ex civic) ecu. that way you willl run on all 16 valves. then get a vafc and put the vtec down to like 4k and start hauling some a$$. Do a search on different setups. there are alot of combos.
Old Jun 26, 2004 | 05:09 PM
specv5150's Avatar
Are you asking this question for OBD reasons. Instead of going OBDII, use a P28 to be ODBI?? I aks because I had another thought. If the VX (D15Z1) and HX (D16Y5) are the same set up (VTEC-E) then couldnt the OBDII guys use the VX ECU to get the best of both worlds. OBDI AND having a VTEC-E ECU
Old Jun 26, 2004 | 05:15 PM
HXvtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by specv5150 &raquo;</TD></TR><TR><TD CLASS="quote">Are you asking this question for OBD reasons. Instead of going OBDII, use a P28 to be ODBI?? I aks because I had another thought. If the VX (D15Z1) and HX (D16Y5) are the same set up (VTEC-E) then couldnt the OBDII guys use the VX ECU to get the best of both worlds. OBDI AND having a VTEC-E ECU</TD></TR></TABLE>
good point . he might be able to do that. try it and find out.
Old Jun 26, 2004 | 05:54 PM
egizzle8
Guest
Posts: n/a
So just run the VX ecu with the y5 head and it should run better than using the p28? I don't feel like going OBDII and going through that hassle. Maybe I'll just get a d15b and call it a day
Old Jun 26, 2004 | 05:58 PM
BauleyCivic's Avatar
Risky Business
Don't put the Y5 head on.
Old Jun 26, 2004 | 06:28 PM
egizzle8
Guest
Posts: n/a
Default Re: y5 mini me in EH (BauleyCivic)
I'm starting to get that idea. Maybe I'll skip the who hassle and just do a d15bvtec swap. Little less of a headache.
Old Jun 26, 2004 | 06:30 PM
specv5150's Avatar
Did you already buy the head??? IF so and you decide against, would you part it out??? LOL
Old Jun 26, 2004 | 06:56 PM
egizzle8
Guest
Posts: n/a
Naw, I didn't buy it yet. I was actually gonna trade a dualcore radiator for it thats just sitting in my garage that I used only once. But after seeing the hassle that I'll have to do to get it to actually run right, I'll just pass. I still have my ITB for a SOHC and maybe pick up a new engine instead of the y5 head. Even if the vx ecu is a vtec-e ecu, would the vtec not kick in till later though being it's not a roller rocker setup like the y5 and then I'd have to wire up the 5 wire o2 sensor. Once again the HX gets the cold shoulder and pushed aside for someone else to figure out.
Old Jun 26, 2004 | 08:16 PM
Kista20's Avatar
the only ecu that will work with a y5 head is the hx computer. The hx has roller rockers arms which is a plus for higher revs. The cam is totally different than that of an ex. IMO I feel like you can get decent power out of a y5 if you know what your doing and build it right. Being an economy model there isn't much support in the aftermarket industry to support it so you would be pretty much on your own.
Old Jun 26, 2004 | 08:18 PM
specv5150's Avatar
Default Re: y5 mini me in EH (Kista20)
on another note...I got raped today by a B16 with some work done.....LOL
The VX didnt have roller rockers too??? Also the VX is a 5 wire O2 I believe???
bk201
Apr 15, 2015 10:06 AM
mxjosh
Sep 15, 2011 08:15 PM
chope045
Jul 15, 2011 11:20 AM
blackbmagic
Oct 6, 2009 05:29 PM
