HELP!! Block swap into my delsol
i have a 94 delsol with the b16a3 stock in my car...im wanting to drop a LS block in my car and turbo....what all is compatible with my block/tranny and the LS block (B18B). Like what all would i need ? please help ASAP thanks
basically im doing the internals in the LS block and doing LS/VTEC with my B16a3 head ...like rods pistons bearings.. but what i need help on is what can i use on my current car with the ls block...example...water pump? oil pump? ecu? wiring harness? tranny?
remember i have delsol with b16a3 stock thanks
I see that you are online. I just posted a question regarding my Honda Del Sol.
Do you know of any interchangeable parts for this car with other Honda's. The front left park/turn light unit is my problem.
no its perfect...i just dont want to take a chance in blowing my motor up because it has 130K miles on it.... and i dont think that it could handle running 12's for very long like im planning to set up
From: I live in a town with Boston traffic, mass, united states
your gonna spend more money building a reliable ls/vtec that can handle boost then you would spend getting the b16 block built for boost IMO
Well, this is your daily driver, and you want it to be reliable?? Then bulletproof the bottom end. Some may hold up to 300whp but not for long as a built setup.
I'd say if you're building the motor and you have to keep the one you got now cause you got to drive around, Just stay with a LS motor. Going with a vtec and boost is going to take lots of money and time. Just keep it simple, and in terms of reliability a frankenstein setup and boost will just limit that.
Decisions, decisions....
