Idle RPM adjustment with A/C On
Hi All,
I just got the 82 Accord up and running, and converted/charged the A/C from R12 to R134a. (A/C blew warm air before... Old stuff I guess, no signs of leaks) Here's the problem, when I turn the A/C on at idle, the RPM's drop to about 200 and runs extremely rough, or it dies completely.
I remember a Honda mechanic showed me the vacuum adjustment somewhere around the carb on my old 81 Accord, that you adjust for correct idle while the A/C is on, but I can't remember where it was, nor can I find anything like it. Maybe they changed it with this model year?
I've already changed spark plugs, wires/cap/rotor OK, timing is good, refridgerent pressure is at normal levels.
If anything, I can drive with the A/C on, I just have to turn it off before I come to a stop... Or play with the gas/brake/clutch all at once while coming to a stop.
... Nah...
Thanks in advance!
... Nah...
Thanks in advance!
Yes there should be an idle boost diaphram on the drivers side of the carb, that opens the throttle plate slightly. It has a phillips head screw adjustment on the stop lever. It is activated by a solenoid on the firewall.
Hunng
Oct 11, 2008 02:43 PM
