I'm getting CEL codes 3, 10, and 21...need help!
Old Jun 25, 2004 | 10:46 PM
handa's Avatar
Default I'm getting CEL codes 3, 10, and 21...need help!
First of all, I'm running a 93 civic ex with a stock jdm b16a gen2 and getting CEL codes 3, 10, and 21.
03=manifold absolute pressure sensor (MAP)
10=intake air temperature sensor (IAT)
21=VTEC spool solenoid valve (*fixed)
I fixed code 21 and noticed VTEC is still not working. Could code 3 and 10 be the reason behind this? My MAP sensor wire is just hanging there behind the intake manifold. I have no clue where the MAP & the IAT sensors are. Anyone got a clear picture of them on the JDM B16A gen2?
Old Jun 25, 2004 | 10:54 PM
Combustion Contraption's Avatar
code 10 wont cause you to not engage vtec so it must be the map sensor doing this.
the map sensor should be on top of the throttle body and as far as the IAT sensor im not sure for the b16's if its on the intake arm or the intake manifold. most are on the intake manifold.
Old Jun 25, 2004 | 11:01 PM
handa's Avatar
Default Re: (LsVtec92Hatch)
my b16a does not come with the MAP sensor on top of the throttle body though
Old Jun 25, 2004 | 11:25 PM
JDMlyfestyle's Avatar
if you have the SIR II swap you should have a Map sensor. at least 3 of my friends that have the same swap have that sensor
Old Jun 25, 2004 | 11:30 PM
handa's Avatar
Default Re: (JDMlifestyle)
my throttle cable looks almost exactly like this:
No holes of any kind for the map sensor on top of the throttle body.
anybody else have an idea?
EDIT:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">When I got my front clip with the JDM b16 the map sensor was on the firewall also if that helps</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Just like the last of the guys are saying you have to get a map and mount it to the fire wall run a tube to the tb and youll be good
They dont have maps on the jdm b16s
Modified by handa at 3:34 AM 6/26/2004
Old Jun 26, 2004 | 07:59 AM
drewlee's Avatar
Default Re: (handa)
If you want you could run your stock ex tb until you can upgrade and buy a itr or h22 one. I ran my z6 throttle body for awhile since I had a 1st gen b16 and it did not come with a map sensor.
Old Jun 26, 2004 | 08:03 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: I'm getting CEL codes 3, 10, and 21...need help! (handa)
It's been a while since I actually did a swap, so forgive me here if I'm off.
Is it possible that you have the MAP sensor and IAT sensir plugs reversed? I know that there are two sensors that have the same plug, and it's MAP and something else. Maybe IACV if not the IAT.
***EDIT***
I just saw that your MAP sensor is absent. Yeah grab one off of your old engine and mount it on the firewall and run the vacuum lines to it from your TB. The suggestions above are correct.
Your IAT sensor should be on your intake manifold, on one of the runners. It should have two wires going to it.
Old Jun 26, 2004 | 12:38 PM
drewlee's Avatar
Default Re: I'm getting CEL codes 3, 10, and 21...need help! (B18C5-EH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 &raquo;</TD></TR><TR><TD CLASS="quote">Is it possible that you have the MAP sensor and IAT sensir plugs reversed? I know that there are two sensors that have the same plug, and it's MAP and something else. Maybe IACV if not the IAT..</TD></TR></TABLE>
The two same ones are the tps and map sensor. They are very close and are easy to hook into the wrong one
Old Jun 26, 2004 | 01:29 PM
the shorter one is the tps, i would give you wire colors but i dont have chart handy
Old Jun 26, 2004 | 06:01 PM
handa's Avatar
This is a typical B16a sensor setup. I know I'll have to use my z6 Map sensor and put it on the firewall since mine is not on top of the throttle body.
Can someone tell me if I labeled these right?
Old Jun 26, 2004 | 06:10 PM
Turbogixxer's Avatar
Default Re: (handa)
Any do you have your Map sensor mounted?
Also, check the hose for kinks and soft spots.
Old Jun 26, 2004 | 06:19 PM
drewlee's Avatar
that is correct on the map and tps and iat, It would prob be just as good to use the ex tb since when I took off my obd0 b16 one it didnt look any wider... but when I looked at the 00si tb you could tell a big difference in the size
Old Jun 26, 2004 | 06:26 PM
Default Re: (drewlee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drewlee &raquo;</TD></TR><TR><TD CLASS="quote">that is correct on the map and tps and iat,</TD></TR></TABLE>
IAT sensor DOES NOT have the same plug as TPS/MAP/EGR.
If the motor is a OBD0 with the OBD0 intake and TB, You can not put a OBD1+ TB on it, it will have a huge vaccum leak and rev straight to 5000 RPM.
Old Jun 28, 2004 | 06:31 AM
drewlee's Avatar
Default Re: (turbogixxer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer &raquo;</TD></TR><TR><TD CLASS="quote">
If the motor is a OBD0 with the OBD0 intake and TB, You can not put a OBD1+ TB on it, it will have a huge vaccum leak and rev straight to 5000 RPM.</TD></TR></TABLE>
I stand corrected. You do have to use a obd1 intake manifold if you want to run your ex tb.
Modified by drewlee at 12:26 PM 6/29/2004
robbys89
Dec 22, 2009 09:31 AM
crfr230
Apr 21, 2007 09:44 PM
crfr230
Apr 20, 2007 05:12 PM
jay-d-em
Sep 7, 2006 05:07 PM
jdmrealm
Jan 31, 2002 12:33 AM
