is my clutch going out?
Old Jun 25, 2004 | 08:11 PM
ieatrice's Avatar
Default is my clutch going out?
i let taught my friend how to drive stick on my car today. it's a stock d16z6 si hatch. she was so HOT, i couldn't resist!!!
anyway, when i was driving home.. my clutch felt really weird. it's not as stiff as it was before, and it doesn't grab instantly when i switch gears. i knew something was up, so i took it all the way from 1st-3rd, i notice between the shifts.. the rpms were slipping. for instance, when i took it to 7200RPM, and shifted to second and mashed the gas pedal, the RPMS still dropped!! it started to grab like a almost 2 second later. is my clutch going out? oh NOsssssss!
Old Jun 25, 2004 | 08:25 PM
c_buz's Avatar
Default Re: is my clutch going out? (ieatrice)
I doubt it. It's probably all in your head. Even if it's going that means you get to upgrade to an aftermarket
Old Jun 25, 2004 | 09:46 PM
igyloo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ieatrice &raquo;</TD></TR><TR><TD CLASS="quote">i let taught my friend how to drive stick on my car today. it's a stock d16z6 si hatch. she was so HOT, i couldn't resist!!!
anyway, when i was driving home.. my clutch felt really weird. it's not as stiff as it was before, and it doesn't grab instantly when i switch gears. i knew something was up, so i took it all the way from 1st-3rd, i notice between the shifts.. the rpms were slipping. for instance, when i took it to 7200RPM, and shifted to second and mashed the gas pedal, the RPMS still dropped!! it started to grab like a almost 2 second later. is my clutch going out? oh NOsssssss!</TD></TR></TABLE>
RPMs dropped huh?
Old Jun 25, 2004 | 09:58 PM
stockegsix's Avatar
I can teach her for you if you want, I could care less about my exedy clutch
Old Jun 25, 2004 | 10:02 PM
SleeperEG-B's Avatar
hmmm - fry your clutch BUT - possibly score with a hot chick? Hey, even if she did f up your clutch, maybe it would be worth the $200+ replacement/upgrade to a new one anyway??
First - Why are you shifting at 7200 RPM? Do you drive like this often? If so, THAT <U>may</U> be the cause of clutch slippage / wearing.
Second
- There is usually a distinct smell associated with burning / glazing clutches that is hard to miss - If you smelled something weird, it might be a clue that she might have messed up the surface a little...
Third - Please don't take offense - But there's no such thing as RPMS - The acronymn for RPM is:
Revolutions... (Notice Plural)
Per
Minute
By saying RPMS you are saying "Revolutions per Minutes..."
Well, even if the clutch is a little worn - I say it might have been worth it - So, did she sign up for lesson # 2???? hahahah
Old Jun 25, 2004 | 10:04 PM
stockegsix's Avatar
Default Re: is my clutch going out? (SleeperEG-B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleeperEG-B &raquo;</TD></TR><TR><TD CLASS="quote"> So, did she sign up for lesson # 2???? hahahah</TD></TR></TABLE>
hey i called it first....
Old Jun 25, 2004 | 10:23 PM
ieatrice's Avatar
lol, no i don't usually shift at 7200. i only went that high to see if my clutch was ok. i think it's slipping yeah, i think it was worth the the burnt clutch! it's hot to see a chick drive a stick!! "put ur left foot on the clutch, and your right hand on my shifter - i mean the shifter!"
oh yeah, i was at the local mobil, and i picked up one of their flyers.. and it was like a sign, i tell u!! oem clutch kit + labor for 137.99
Old Jun 26, 2004 | 06:53 AM
ieatrice's Avatar
bump!
Old Jun 26, 2004 | 09:11 PM
ieatrice's Avatar
no one knows?
Old Jun 26, 2004 | 09:51 PM
TommyTom83's Avatar
how many miles do you have on it? if it was slipping rpm's shouldnt drop they should actually stay up if the clutch is slipping. like if you slammed second you hear it kind of rev up then drop back down and engage if it was slipping. at least that has been my experience
STEVE-O7
Oct 10, 2007 05:18 PM
mikseries
Honda Civic (2006 - 2015)
11
May 21, 2007 06:00 PM
Cypher0117
13
Jul 19, 2005 07:39 AM
Cypher0117
23
May 16, 2005 07:15 PM
91B17A_Teggy
Aug 26, 2004 04:52 PM
