What is everyones timing set at on H22a swaps
Old Jun 25, 2004 | 07:16 PM
staticrex's Avatar
Default What is everyones timing set at on H22a swaps
I am trying to find a good medium for my timing, for a daily driver. I want to see where everyone else has theres set? How much advanced or how much retarded?
Thanks
Old Jun 25, 2004 | 09:59 PM
AMS MIKE's Avatar
Default Re: What is everyones timing set at on H22a swaps (staticrex)
14-17 degrees is what is reccomended by Honda and Smog Laws of a H22
I usually set H22's to 15 degrees on a stock motor
Old Jun 26, 2004 | 12:26 AM
Eddiebx's Avatar
from what i've seen on the dyno, h22s, like alot of timing, i have gone as far as 22deg BTDC, but that was dyno tuned, so i dont suggest you run it that far.
I would stick it at 17, and u will be safe, and pick up some low end.
Old Jun 26, 2004 | 09:39 AM
LudeyKrus's Avatar
Mine's at 15 degrees.
I will eventually bump it up a few more.
Old Jun 26, 2004 | 05:08 PM
v4lu3s's Avatar
RTFM
all stock on 2 cars, and the third i run at 18 btdc normally.
Old Jun 27, 2004 | 05:42 PM
staticrex's Avatar
Default Re: (v4lu3s)
allright sounds good. Would a weird metallic noise at start up be a symptom of the motor being timed incorrectly? Or out of specs?
I just replaced the distributor and there is a metallic noise on start up, could this be a faulty distributor or installed incorrectly?
thanks
Old Jun 27, 2004 | 10:12 PM
SKDRCR's Avatar
Default Re: (staticrex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by staticrex &raquo;</TD></TR><TR><TD CLASS="quote">allright sounds good. Would a weird metallic noise at start up be a symptom of the motor being timed incorrectly? Or out of specs?
thanks</TD></TR></TABLE>
when you say metallic noise, do you mean like a pinging sound?
if so, your timing might be too far advanced. do you have a timing gun?
Old Jun 27, 2004 | 10:51 PM
staticrex's Avatar
Default Re: (SKDRCR)
no its not a pinging noise, I have a durango 5.9L believe me I know wht a ping sounds like ( dodge sucks ).
It sound like two metals tapping eachother, for the first few minutes of warming up. after that it goes away.
30psi_gst
Engine Management and Tuning
Dec 3, 2010 11:08 PM
FlewByU352
Nov 13, 2010 07:27 PM
bburtonsk8r2
Apr 20, 2006 05:32 PM
turboH22Aakkord
Jul 7, 2005 08:29 AM
