Skunk2 camber kit is squeaking...
Don't know what would cause it, but if you put a little automatic tranny fluid on it, it may go away. I have this same problem with my Camber kit, except its on the right rear. The rubber fell out somehow and now the metal is rubbing against the metal and squeaking. WD-40 will work too, but the auto tranny fluid works for a longer time. Inspect it to see why its squeaking, maybe you'll need to return it.
I had to have my camber kit shaved a little bit. it didn't squeak it made a rubbing noise pretty bad on my R. I couldn't figure out the problem so i had a local shop help me out and they figured out that was the problem.
mine never squeaked though
I would think any automatic tranny fluid would work. Just depends on what is making the squeak. It worked for me, but like these other dudes, it wouldn't have worked for them really.
https://honda-tech.com/zerothread?id=838684
Check in that thread for the issues with the arm hitting the body. Solved with a little angle grinder action.
