bigger fuel injectors....hurt me?
i have a access to a set a lager fuel injectors (h22),a guy on ht.com told tht bigger injectors mite hurt me a bit since i dont have a crazy big setup, i belive my stock ones are (b18)240cc and the h22 are 320..
If your setup is mild (it would be helpful to post your actual setup) and you don't have a means of fuel tuning, I would leave the injectors stock. Out of curiosity though, what year Prelude are the injectors from?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kal »</TD></TR><TR><TD CLASS="quote">obd1 preludes had 345cc injectors.
obd2 preludes had 295cc</TD></TR></TABLE>
Exactly why I was asking - that and the fact that the OBD1's are peak & hold, while the OBD2's are more "plug-and-play friendly" saturated.
exactlly i have a set of 345s by the way
95 jdm h22 exhaust mani $75
spearco 24x3.5x7 (core) intercooler$300
01 type r fuel pump $75
98 civic fuel filter with braket and hose $50
98 ex throttle body no sensors$50
legit 95 civic grey air bags $75 each
18" racing hart c2s powder coated midori green pearl centers with polished lip and toyo 215/35/18 mint no scratches at all$950
95 jdm h22 fuel rail and injectors 345cc $100
msd rpm activated switch $50
like new black t-fal super cool fan for civic $100
99 civic factory radiator $75
95 civic factory radiator with fan/shroud/and hoses $75
3" aem cold air intake like new powdercoated midiori green with bypass valve $125
95 jdm h22 intake manifold complete $100
h22 balance shafts $75
95 jdm h22 pistons and rods 22,000 miles on them mint 10.5 to 1 comp. $100
95 jdm h22 valves and springs mint $100
misc.civic ecu email with needs
2 sets place racing stage 2 axels for h22 in 96-00 civic make offer
b&m short shifter for h22 $50
new genuine 00 jdm civic type r head lights with h.i.ds $550
hks racing blow off valve with 20psi releif spring $125
2 genuine 16" racing hart cpo35r custom powder coated flat blck (lightest 16" wheel you could buy)same as whats on jeremys car with nitto 555rs these are pretty much brand new$650
factory 96-00 civic side skirts $75
factory 96-98 civic right and left fender oem $125
Modified by h22 civic at 9:17 PM 5/31/2004
bigger fuel injectors won't hurt if you can tune them (off course, to a limit)
so, it basicly narrows down to are you going to tune it or not?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">If your setup is mild (it would be helpful to post your actual setup) and you don't have a means of fuel tuning, I would leave the injectors stock.</TD></TR></TABLE>
Since you're so close to stock, don't bother with them.
Fuel is fuel - you won't get some performance increase just because they are a bigger injector.
