Is installing an AEM Tru Time Adjustable Cam Gear worth it without an aftermarket camshaft?
Old Jun 25, 2004 | 06:50 PM
Buktheng's Avatar
Default Is installing an AEM Tru Time Adjustable Cam Gear worth it without an aftermarket camshaft?
Is it worth it and how hard is it to install? What steps do I have to do and watch out for.
Old Jun 25, 2004 | 06:52 PM
BauleyCivic's Avatar
Risky Business
Default Re: Is installing an AEM Tru Time Adjustable Cam Gear worth it without an aftermarket camshaft? (Kho
It's worth it but you need to have it dyno tuned. If it isn't tuned it is worthless.
Old Jun 25, 2004 | 06:55 PM
Buktheng's Avatar
What do they do
Old Jun 25, 2004 | 07:04 PM
Buktheng's Avatar
Opps....
Old Jun 25, 2004 | 07:11 PM
Littleredsi's Avatar
They allow you to change the acutal time of the camshaft. So basically when the valves open and close in relation to position of the pistons.
To do this properly and get its full potential you do need to have it dyno tuned.
Basically it is moving the power band up or down in the rpm range, trying to take advange of other mods that you have done to your car.... if any !!
Retard Timing = Higher RPM power
Advanced Timing = Lower RPM power.
Old Jun 26, 2004 | 06:46 AM
Buktheng's Avatar
I need higher rpm power so I would retard the timing eh...
Old Jun 26, 2004 | 06:58 AM
gsrswapdcivic's Avatar
AEM gears are **** i know 2 people who had them and both had the bolts strip out, they had to drill them. get some better gears if you do buy some i recommend spoon skunk2 or toda i have had all on diff. motors and work very well. i like the design with more then 3 bolts on it. just my opinion good luck in any venture.
articbluedc5's Avatar
I was just about to ask good info
Old Jun 26, 2004 | 07:36 AM
ebp 99 si's Avatar
i had the aem's on my old si but i never had it dynod so they were pretty much useless
like bauley said get the car dynod to take advantage of them
right now i'm looking for the new bronze str cam gears and a set of type-s cams for my hatch
Old Jun 26, 2004 | 08:45 AM
Buktheng's Avatar
Bogus man, you guys know any place around the Philly area or NJ that can dyno tune and how much does it cost?
Old Jun 26, 2004 | 06:55 PM
Buktheng's Avatar
Anybody....
Old Jun 26, 2004 | 06:59 PM
Tuning 101's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Bogus man, you guys know any place around the Philly area or NJ that can dyno tune and how much does it cost?</TD></TR></TABLE>
Down here it's like $60 a run.
Old Jun 27, 2004 | 10:15 AM
Cynical 1's Avatar
If it's a single cam engine, you're wasting money. You'll see a minimal gain, and only on a dyno...
It will be able to shift your powerband, but only by a couple hundred RPM, and it may affect driveability...
Old Jun 27, 2004 | 10:31 AM
ransack's Avatar
I believe you can take the cam gear and advance the timing with it. Getting you more HP. Alittle, but some at least? But you DO NEED TO get it dyno tuned to most efficent results
Rich EX
Honda Civic (2001 - 2005)
Apr 20, 2006 01:25 PM
Blown90hatcH
Apr 21, 2005 01:27 PM
SexyH22
Oct 31, 2004 08:05 PM
kenepo
Feb 18, 2003 06:38 AM
dpo95si
Aug 15, 2002 06:45 AM
