Someone must be wrong
Old Jun 25, 2004 | 04:29 PM
db2integra's Avatar
Default Someone must be wrong
According to Cspeed's calculator, a -9.3 cc dome piston in a GSR will yeild 8.74:1 compression ratio. According to the manufacturer of said piston JE, it is a 9.0:1 piston for the GSR. Someone must be wrong here. This was done for a .020 oversized piston, but it is wrong for the stock bore 81mm piston as well.
Old Jun 25, 2004 | 04:54 PM
db2integra's Avatar
Default Re: Someone must be wrong (db2integra)
Anyone have an idea? I have these pistons in my kitchen, but if they are actually lower compression than advertised, I think I will want to raise it.
Old Jun 26, 2004 | 10:49 AM
db2integra's Avatar
Old Jun 26, 2004 | 12:09 PM
Sack Master's Avatar
I just did a calculation with a .020(3.209) overbore, same size head gasket(3.209), .042 thick, with a .003 deck clearance, stock stroke, stock cc head, and came out with a static compression ratio of 9.004:1. I'm sure it will be a little different than that. But that's pretty close. What size head gasket does JE say to use with those pistons?
Old Jun 27, 2004 | 07:08 AM
db2integra's Avatar
Default Re: Someone must be wrong (Sack Master)
So CSpeed calculator=crap I guess. I won't use that thing again.
Old Jun 27, 2004 | 08:02 AM
Joseph Davis's Avatar
I was told a few months back the C-Speed calculator is a little off.
B18 CYA
Dec 12, 2005 02:21 PM
Takumi Fujiwara
26
Apr 16, 2005 04:22 AM
Hoodwinked
Jan 19, 2004 08:34 PM
I_know
Dec 21, 2002 07:07 AM
C-speed
Oct 17, 2001 10:11 PM
