Endless CC-X on new rotors?
Old Jun 25, 2004 | 04:29 PM
Project X's Avatar
Default Endless CC-X on new rotors?
I'm able to get some new Brembo blank rotors. While I'm at it, I am planning to change the stock ITR brake pads to some "used" Endless CC-X ones. Is it okay to use these Ceramic Carbon Metal brake pads to break in the new rotors or should I use the stock one instead?
Old Jun 25, 2004 | 04:31 PM
BlueR's Avatar
Default Re: Endless CC-X on new rotors? (Project X)
go ahead, nothing wrong with it...they are going to chew on the rotors whether you install them now or later
ideally, you want one type of pad per set of rotors
Old Jun 25, 2004 | 06:03 PM
Flux's Avatar
Default Re: Endless CC-X on new rotors? (BlueR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR &raquo;</TD></TR><TR><TD CLASS="quote">go ahead, nothing wrong with it...they are going to chew on the rotors whether you install them now or later</TD></TR></TABLE>
My CC-X pads have been very rotor friendly...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueR &raquo;</TD></TR><TR><TD CLASS="quote">ideally, you want one type of pad per set of rotors
We all know that never happens with all the track rats around here...
Old Jun 28, 2004 | 11:24 AM
Project X's Avatar
Default Re: Endless CC-X on new rotors? (Flux)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flux &raquo;</TD></TR><TR><TD CLASS="quote">
How are they even in cold weather?
We all know that never happens with all the track rats around here... </TD></TR></TABLE>
That's true, unless people is crazy (or rich) enough to change rotors everytime they change brake pads.
Old Jun 28, 2004 | 11:39 AM
Flux's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Project X &raquo;</TD></TR><TR><TD CLASS="quote">How are they even in cold weather?
They have been fine. I'm in Texas, so most of the time it stays fairly wartm around here - but there are days when it gets cold and I haven't noticed any problems. These are my everyday pads.
Old Jun 28, 2004 | 01:25 PM
BlueR's Avatar
i'm from up north where we have real winters, no offense to Flux
and my rotors were pretty chewed up bc of the cold
and they were also my everyday pads
Note: the pads were the best pads i have ever used, i wholeheartedly recommend them if you have the money
i also tracked these pads heavily if it makes a difference on the rotors
Old Jun 28, 2004 | 01:28 PM
Mike M's Avatar
Founding Member
My CC-X pads have been very rotor friendly...</TD></TR></TABLE>
Exactly, Mine have been great as well. The pads work just as good in the cold weather, Only time I had to do a quick stop or two to warm them up was when it was mid winter and about 10-20 degrees outside.
Old Jun 29, 2004 | 11:21 AM
Project X's Avatar
Default Re: Endless CC-X on new rotors? (Mike M)
Any squealing during the warm up time?
Old Jun 29, 2004 | 11:50 AM
BlueR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Project X &raquo;</TD></TR><TR><TD CLASS="quote">Any squealing during the warm up time?</TD></TR></TABLE>
mine never made a sound...i got real lucky
Old Jun 29, 2004 | 12:50 PM
CPR's Avatar
CPR
Mine are starting to squeak frequently after a year which includes 4 track days and daily driving usage.
Old Jun 29, 2004 | 12:59 PM
Flux's Avatar
Not really. I will hear a small squeal just every so often - but it is rare.
Old Jun 29, 2004 | 01:45 PM
nsxtasy's Avatar
H-T Order of Merit
Mine squealed a lot. A REAL lot. Enough that I stopped using them.
Otherwise, their performance was fine. Nice stopping on the track, and held up to track abuse very well. They worked fine in the cold, too.
Old Jun 29, 2004 | 05:23 PM
Project X's Avatar
Default Re: Endless CC-X on new rotors? (nsxtasy)
From you track guys experience, it sounds like these pads will start squealing once it gets worn down to a certain level.
Mikes2000civicsi
10
Jan 14, 2007 04:35 AM
JDM_SOHC
25
Nov 15, 2006 06:49 AM
matto2413
Feb 1, 2005 03:31 AM
wpsadmin
Jan 18, 2005 11:27 AM
petrv
Jan 17, 2005 04:58 PM
