another azenis question
Old Jun 25, 2004 | 10:48 AM
[HrZn]4life's Avatar
Default another azenis question
So I finally hopped onto the bandwagon and picked up some 205 50 15 azenis. I did a search and found many, many, many threads on azenis but no answer to my question. I was just wondering what tire pressure you guys recommend for daily driving on the azenis. I don't have another set of wheels/tires to use and I want to use these for track duties and daily driving. What pressure what you guys recommend for durability on the street. Thanks.
Old Jun 25, 2004 | 02:37 PM
type r 01-1063's Avatar
Default Re: another azenis question ([HrZn]4life)
I set mines to 34-35psi front, 31-32psi rear
Old Jun 25, 2004 | 02:38 PM
Bbasso's Avatar
I liked 35f37r...
Old Jun 25, 2004 | 03:39 PM
1GreyTeg's Avatar
Try even pressures front and rear, maybe 35 all around, then play with them (raise or lower them) to see if the front sidewalls rollover or if you care for more rotation from the rears.
Pressures are preference. Some people play with them all the time and feel they make a huge difference. Others keep the same pressures, rarely changing them and are satisfied.
I tend to use the same cold pressures for the Azenis at autocross as I do on the track; 35 to 36 front, and 32 to 34 rear. I only mess with them to bleed down after they might get to hot or if I really feel something amiss. But again this is totally personal preference.
Old Jun 25, 2004 | 04:12 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Default Re: another azenis question (1GreyTeg)
i run 34/34 on the street and 40/30 for autoxing.
Old Jun 25, 2004 | 04:54 PM
magic hat #9's Avatar
Default Re: another azenis question (SkyeC)
azenis on track tend to like 38-40psi HOT; higher pressures tend to make them get greasy quicker.
Old Jun 25, 2004 | 07:39 PM
Default Re: another azenis question (magic hat #9)
I guess my question is more directed towards what pressures I should use if I want them to last as long as possible on the street; if they last long on the street then i'll have something I can use on the track still. Thanks guys.
Old Jun 26, 2004 | 05:32 AM
George Knighton's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [HrZn &raquo;</TD></TR><TR><TD CLASS="quote">4life]I guess my question is more directed towards what pressures I should use if I want them to last as long as possible on the street....</TD></TR></TABLE>
Be aware that they're not long lived tyres, no matter what pressures you use.
36 F / 35 R is what I use on the street and they seem to last about as long as a tyre like that is going to last.
Don't worry about it. They're cheap.
BoltonGSR
53
Aug 10, 2008 07:51 PM
Batoutahell
Feb 3, 2005 05:47 AM
Vracer111
30
Oct 21, 2004 03:23 PM
mr_mbuna
Sep 26, 2002 01:58 AM
Junglist
Jul 25, 2002 12:52 PM
