RPM problem
Old Jun 25, 2004 | 09:17 AM
chansw's Avatar
Default RPM problem
Goodday folks,
It used to rev 2500rpm to maintain 100km/h. Recently this happens only 1/10 times.
Remaining 9/10 times it revs 2750rpm to maintain 100km/h.
Any thoughts? Thanks in advance.
Old Jun 25, 2004 | 10:13 AM
Nick H's Avatar
New User
Default Re: RPM problem (chansw)
auto or manual?
Old Jun 25, 2004 | 09:05 PM
chansw's Avatar
Default Re: RPM problem (Nick H)
It's an auto.
Old Jun 25, 2004 | 09:11 PM
Starrman85's Avatar
are you by chance running the A/C during any of those times? that MIGHT have a affect on your RPM's.
Old Jun 25, 2004 | 09:20 PM
chansw's Avatar
Default Re: RPM problem (STARRMAN85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STARRMAN85 &raquo;</TD></TR><TR><TD CLASS="quote">are you by chance running the A/C during any of those times? that MIGHT have a affect on your RPM's.</TD></TR></TABLE>
I'm sure A/C has impact on RPM but not as much as 250rpm at 100km/h.
An hour ago I revved on D3 to 5500rpm then shifted to D4 and it gave me 2500rpm at 100km/h again. Slowed down to 60km/h then sped up to 100km/h, again at 2750rpm or equivalent to 60mph@3250rpm.
Need some sort of tuning I guess? Thought the mechanic already done that couple of weeks back.
Old Jun 25, 2004 | 09:42 PM
Crank's Avatar
did u change your rims or tires? that might be it
Old Jun 26, 2004 | 12:17 AM
danyo14's Avatar
Default Re: RPM problem (Crank)
i think it might b ur idle sensor...it use to happen to my car to..and i changed it..n it went back to normal..a maybe...
Old Jun 26, 2004 | 05:21 AM
chansw's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crank &raquo;</TD></TR><TR><TD CLASS="quote">did u change your rims or tires? that might be it </TD></TR></TABLE>
Nope, no tire/rim change. If I were to get larger rims/tires, shouldn't RPM be lower for the same speed instead?
Thanks for the thought!!
Old Jun 26, 2004 | 05:23 AM
chansw's Avatar
Default Re: RPM problem (danyo14)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by danyo14 &raquo;</TD></TR><TR><TD CLASS="quote">i think it might b ur idle sensor...it use to happen to my car to..and i changed it..n it went back to normal..a maybe...</TD></TR></TABLE>
Where's the idle sensor? This sensor has effect even when the car is running? Sorry I'm still learning!
Thanks!
Old Jun 27, 2004 | 06:26 AM
chansw's Avatar
Hi,
More unusual behavior found.
When I release accel pad, usually RPM will gradually decrease.
Now it will drop drastically, eg from 2500rpm@100km/h to 1500rpm@95km/h a second later. I'd say it's "not holding the speed".
Is there something like overdrive in F22B1? I did notice RPM drop of 250 at D4 after reaching certain speed usually around 60 ~ 90km/h.
Anyone has any idea?
Thanks!!!!
Old Jun 27, 2004 | 07:14 PM
95blk2draccordEXMT's Avatar
sounds like something is a lil worn in your engine or drivetrain system, which will lower the output of your machine. It sounds like your engine isn't putting out as much power to the wheels as it used to, thus it takes a higher rpm range and thus more power in your honda to keep the car steady. Something is dragging that output to go down. This will also explain why your engine will slow dramatically when you let off on the gas. Could be a number of things... one of the most simple things... have you changed your oil lately?
Old Jun 28, 2004 | 08:57 PM
chansw's Avatar
Default Re: RPM problem (95blk2draccordEXMT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95blk2draccordEXMT &raquo;</TD></TR><TR><TD CLASS="quote">sounds like something is a lil worn in your engine or drivetrain system, which will lower the output of your machine. It sounds like your engine isn't putting out as much power to the wheels as it used to, thus it takes a higher rpm range and thus more power in your honda to keep the car steady. Something is dragging that output to go down. This will also explain why your engine will slow dramatically when you let off on the gas. Could be a number of things... one of the most simple things... have you changed your oil lately?</TD></TR></TABLE>
About 2600km (1625 miles) driven since last oil change.
And this unstable RPM happens intermittently. Sometimes I get the regular RPMs.
Old Feb 28, 2005 | 11:17 AM
tr3-2001SE's Avatar
I have this exact same issue. Wonder if anyone has any new ideas on this one. Might it be the coil as I guess the tack works off the ignition coil.
Old Mar 1, 2005 | 12:43 AM
accorderator's Avatar
sorry not to be off topic.. how come sometime when i let off the gas at 45mph, and rpm goes down and then sometimes it rises quickly and the decreases, like a wave , but only once..thanks!
vang
Aug 24, 2008 01:36 PM
Soon2RideEX05
Honda Civic (2001 - 2005)
13
Jan 9, 2008 01:32 PM
masteroflife67
Oct 13, 2005 06:28 AM
SOLO1racer
Jan 25, 2005 07:37 PM
94cord_ex
Mar 13, 2004 07:00 PM
