Speedo Adjustment
If I change my cluster, Is there any way to adjust my new cluster to match the mileage of my old cluster? Of course we are taking into account the new one has less miles on it.
Alright man, I've done this a million of times. Here is what you can do, very simple. Whichever cluster that you want to adjust your miles on, pop the plastic front cover off of it using a a couple of flathead screwdrivers pushing the tabs in the back. Than what you need to do is either get a small flathead, or pencil with an eraser, or those dental utililities used to remove plaque-it has a rubber hook at the end. Than all you have to do is gently move the numbers up, one by one starting with the last digit to your right. Simple.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoCalB16a2 »</TD></TR><TR><TD CLASS="quote">Alright man, I've done this a million of times. Here is what you can do, very simple. Whichever cluster that you want to adjust your miles on, pop the plastic front cover off of it using a a couple of flathead screwdrivers pushing the tabs in the back. Than what you need to do is either get a small flathead, or pencil with an eraser, or those dental utililities used to remove plaque-it has a rubber hook at the end. Than all you have to do is gently move the numbers up, one by one starting with the last digit to your right. Simple.
which is illegal if it's not documented by a speedo shop. but with all sorts of ppl running jdm guages etc =\ i dont think many ppl care anyway
</TD></TR></TABLE>which is illegal if it's not documented by a speedo shop. but with all sorts of ppl running jdm guages etc =\ i dont think many ppl care anyway
I appreciate all the advice. Legal and illegal. I was interested in the legal ones actually, that is why I am asking this question to keep the miles as true as possible. So any speedo shop can do this and document it properly?
who cares.....most of the things u do to your cars is illegal anyway.....just do what the guy up top said....thats the way i adjust my brothers Integra cluster when he did a dash swap into an EH
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JRI94 »</TD></TR><TR><TD CLASS="quote">
Look what I found!
https://honda-tech.com/zerothread?id=837111</TD></TR></TABLE>
I tried that but the results you get depends on what you put in the search.
Look what I found!https://honda-tech.com/zerothread?id=837111</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ashnice »</TD></TR><TR><TD CLASS="quote">
I tried that but the results you get depends on what you put in the search.</TD></TR></TABLE>
I typed odometer...
You must search "recent" and "archived".
I typed odometer...
marecco
Mar 11, 2008 11:58 AM
TegoDC5
Aug 30, 2005 07:45 PM
Sliced Beard
Aug 28, 2004 03:03 PM
xdjoynerx
Mar 6, 2004 10:46 PM
