Brake Question
Old Jun 25, 2004 | 07:24 AM
shannon's Avatar
Default Brake Question
when I have my AC on ,and push the brake pedal the pedal goes all the way to the floor . What's the cause of this???
Old Jun 25, 2004 | 10:42 AM
shannon's Avatar
Default Re: Brake Question (shannon)
ttt
Old Jun 25, 2004 | 05:44 PM
Hawkze_2.3's Avatar
Only when you have the AC on?? Those two components are not related in any way I can think of...
Old Jun 25, 2004 | 07:00 PM
IVI's Avatar
IVI
Default Re: Brake Question (Hawkze_56)
they arent related. need more info. it doesnt do it when your ac is off ?
Old Jun 25, 2004 | 07:01 PM
taz77's Avatar
New User
those components are unrelated in terms of parts.
the only connection i can see is that, IF the weather is hot enough for u to turn on your a/c, that there is a chance that it's too hot that you're experiencing brake fade. the only things you can check is the condition of the brake pads and rotors, and make sure you're not using cheap quality crap on your brake system
Old Jun 26, 2004 | 06:59 PM
shannon's Avatar
Default Re: (taz77)
It's only when I have the ac on and it happened after i changed the seals in the right rear callipers.
Old Jun 26, 2004 | 07:12 PM
Hawkze_2.3's Avatar
Default Re: (shannon)
Either it's just coincidence or you have some stuff hooked up very wrong...Did you change or move anything else around the time you did the brakes? Vacuum line or something?....
Old Jun 26, 2004 | 07:39 PM
shannon's Avatar
Default Re: (Hawkze_56)
no I didn't changed anything else but I do remember that when changing the seals all the brake fluid was drained and the reservoir was empty
Old Jun 27, 2004 | 12:35 AM
taz77's Avatar
New User
try bleeding the brakes again.
it might just be a combination of air in the system and the high temps causing the fluid to boil causing the brake fade... at least, it's a start.
i'm assuming you're no longer leaking any brake fluid?
Old Jul 9, 2004 | 05:06 AM
blueiedgod's Avatar
Doesn't the engine load affect vaccum boost? I notice that when A/C pump cycles on and off the pedal sinks a little if I am at a stop light.
SIRR
Honda CR-V & Element
Jul 19, 2011 11:31 PM
civhatch90
May 16, 2005 05:30 PM
verbal
Jun 17, 2004 06:54 PM
AkiraLite
Aug 17, 2002 08:22 AM
PearlWhiteAccord
Jul 19, 2002 10:32 AM
