Fan on Driver's Side-Condensor or Cooling
Old Jun 25, 2004 | 06:29 AM
joeramirez's Avatar
Default Fan on Driver's Side-Condensor or Cooling
The fan on the driver's side of my car just died in addition to the other problems I'm having. Is that the Condensor cooling fan or just the radiator cooling fan. It's a 1996 EX with 4-cylinder V-Tec. The passenger side turns on whenever I turn the A/C on, but someone told me the Driver's side is the one that should turn on. Also, cheapest place online to order a new one? Thanks a million! You guys rock!
Old Jun 25, 2004 | 08:30 AM
Bullethole's Avatar
Default Re: Fan on Driver's Side-Condensor or Cooling (joeramirez)
It is the a/c condeser fan and it should cycle on with the a/c. I recently had one go bad on a 94EX. You can find the motor for around $115-125 on line. I went to a salvage yard and got the whole assembly with shroud for $60.00. Only has three bolts and two plugs. Before you swap it out, unplug it and and give it 12v to see if it is the motor, a short or control problem.
Hobkins
Oct 15, 2012 04:57 PM
jonesdesign
Jun 18, 2009 07:18 PM
89 civic si
Sep 28, 2006 07:14 AM
darkfx
Aug 25, 2005 12:23 PM
