Dual VTEC head springs with Type R cams...
Old Jun 25, 2004 | 04:01 AM
7rrivera7's Avatar
Default Dual VTEC head springs with Type R cams...
I pulled out my Skunk2 Stage 2 cams but left in their valvetrain. I'm running Type R cams right now. Will I lose power because of the spring pressure or worse, prematurely wear my Type R cams?
Old Jun 25, 2004 | 06:53 AM
EKCivicR's Avatar
Why???
Old Jun 25, 2004 | 07:49 AM
7rrivera7's Avatar
Default Re: (EKCivicR)
Why what? Is it ok to run Type R cams with Skunk2 dual springs?
Old Jun 25, 2004 | 07:55 AM
mmuller's Avatar
Mad Scientist
Default Re: (7rrivera7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 7rrivera7 &raquo;</TD></TR><TR><TD CLASS="quote">Why what? Is it ok to run Type R cams with Skunk2 dual springs?</TD></TR></TABLE>
they do put more pressure on the cams/valvetrain, but it will be ok
Old Jun 27, 2004 | 04:48 PM
vtecn8ive's Avatar
Default Re: (mmuller)
I thought that the skunk2 were similar to the itr ones.
Old Jun 27, 2004 | 07:54 PM
beaterdriver's Avatar
my friend ran s2 valvetrain with stock b16 cams. it ran just as it did b4 he put the valvetrain in and he can rev higher.
Old Jun 29, 2004 | 02:07 AM
Xsi's Avatar
Xsi
It should be fine. I think the guy was asking why you pulled S2S2's for ITR's
Old Jun 29, 2004 | 06:43 AM
7rrivera7's Avatar
Default Re: (Xsi)
I didn't have enough compression for the S2S2's so I'm saving them for my GSR buildup.
Old Jun 29, 2004 | 10:29 AM
Sliced Beard's Avatar
it will be fine, actually it is better because you will not have to worry about valve float if you miss shift or something stupid
Bangher4$
Apr 19, 2009 12:54 PM
lilo_goki
May 17, 2007 11:29 PM
Kiniku Chunks!!!
Feb 6, 2007 07:30 PM
94teggieGs-r
Sep 21, 2005 09:44 AM
Trbospnkr
Jul 16, 2003 04:53 PM
