Can a JB Weld hold this together?
Old Jun 24, 2004 | 07:56 PM
lowkey's Avatar
Default Can a JB Weld hold this together?
This is where the bleeder valve for the cooling system is supposted to go.
I over tourqued it and it cracked off.
This is on my B18a.
Can it hold up? or I am SOL.
Old Jun 24, 2004 | 08:04 PM
sabotage7's Avatar
Default Re: Can a JB Weld hold this together? (lowkey)
i would try and stay away from anything thats really liquidy like that bc it may contaminate the system....maybe try a putty or something.....i used this magna steel putty stuff on my radiator once just to hold it until i got a new one, and it worked well....but i dunno....thatd probably look pretty crappy though......good luck on that!
Old Jun 24, 2004 | 10:02 PM
Mr. Softee's Avatar
Default Re: Can a JB Weld hold this together? (sabotage7)
do it.
Old Jun 24, 2004 | 10:22 PM
esponet's Avatar
just remove the whole housing. make sure its clean and dry before you apply jb weld. then make sure the jb weld is completely dry before you install it and run coolant. should hold. but you might not be able to use the bleeder again
Old Jun 24, 2004 | 11:16 PM
Mad Cow's Avatar
Default Re: (esponet)
Yeah, JB Weld will work perfectly. I have some patching a hole in my radiator, it works great.
Old Jun 25, 2004 | 01:11 AM
r34p3r666's Avatar
Default Re: (Mad Cow)
Dude, I just broke the same part a few days ago !!! I ended up jus using a screw with a rubber grommet, been holding up just fine ...
Old Jun 25, 2004 | 04:28 AM
JiggyKooAndy's Avatar
it should be able to. Try and let us know...
Old Jun 25, 2004 | 04:30 AM
ragejed's Avatar
Default Re: Can a JB Weld hold this together? (JiggyKooAndy)
Or just replace that whole part and you can sleep at night...
Old Jun 25, 2004 | 07:36 AM
Malice's Avatar
New User
Default Re: Can a JB Weld hold this together? (ragejed)
jb weld will not hold that together. the vibration from the motor will just break it off
Old Jun 25, 2004 | 08:43 AM
Honda Hick's Avatar
You could JB Weld it temporarily but I would definately look around for a replacement from a junked motor. That's not something you want cracking again on the road.
Old Jun 25, 2004 | 08:48 AM
d0twinx's Avatar
it could work, jb weld works wonders. ive used it to hold a cracked tranny case.
Old Jun 25, 2004 | 09:33 AM
Redtail's Avatar
Default Re: (d0twinx)
You'll have to try to be sure, but I think it will work. I had a buddy who stripped out a spark plug hole on an old s-10 one time, and he JB-welded a new spark plug in and that is still holding after 30xxx. I donno what he is gonna do when it is time to change the plugs though
Old Jun 25, 2004 | 10:14 AM
PM-Performance's Avatar
Default Re: (Redtail)
it will hold fine .
Old Jun 25, 2004 | 11:15 AM
RPRacing's Avatar
easy to find. get a new one, dont be ghetto
Old Jun 25, 2004 | 12:12 PM
WhiteTegSE's Avatar
Default Re: (sucka306)
someone on this site HAS to have one of those laying around... id start a thread and see if someone has one...
Old Jun 25, 2004 | 12:48 PM
BaGGed HoNDa's Avatar
i say use some duck tape
Old Jun 25, 2004 | 12:57 PM
Slo Car's Avatar
Default Re: (BaGGed HoNDa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BaGGed HoNDa &raquo;</TD></TR><TR><TD CLASS="quote">i say use some duck tape</TD></TR></TABLE>
can u say ghetto?? j/k
Old Jun 25, 2004 | 02:14 PM
G-bonic's Avatar
Hijacked
ill say chew a 24 cents gum and put it all over hehehe .. ill say it will hold it temporarily not too long....
Old Jun 25, 2004 | 02:16 PM
Eminent's Avatar
Yup gum will work perfectly
Old Jun 25, 2004 | 02:23 PM
spoonfed95's Avatar
Default Re: (Eminent)
JB Weld it, just drill, tap and your done.
Old Jun 26, 2004 | 07:58 AM
lowkey's Avatar
Default Re: (WhiteTegSE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteTegSE &raquo;</TD></TR><TR><TD CLASS="quote">someone on this site HAS to have one of those laying around... id start a thread and see if someone has one...</TD></TR></TABLE>
Please let me know if you find one.
I am using a screw for now the Jb weld snapped off the next morning.
Old Jun 26, 2004 | 08:23 AM
RPRacing's Avatar
read what WhiteTegSE wrote again
"I'D start a thread." not I'll start a thread.
let me look and see if i have one on a head. i should
Old Jun 26, 2004 | 08:50 AM
lowkey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sucka306 &raquo;</TD></TR><TR><TD CLASS="quote">read what WhiteTegSE wrote again
let me look and see if i have one on a head. i should</TD></TR></TABLE>
Too early in the morning for me
Sucka306 - got a spare one laying around?
Mar_DC2
Dec 27, 2006 06:19 PM
Race Egr
Welding / Fabrication
27
Apr 20, 2005 01:05 AM
rkonfire
Apr 28, 2004 05:17 PM
dingusjt
Feb 15, 2004 01:54 PM
JDM_ITR
Apr 25, 2002 11:56 AM
